anyone knows where i can find motherboard's repair books?
  • layad
    • Nov 2011
    • 244
    at least any book explains the the diagram in details
  • 3d0
    • Jan 2014
    • 159
    • BiH
    Re: anyone knows where i can find motherboard's repair books?
    I'm pretty sure you will not find any book that explains in full detail mb repairs.
    Basically read electronics related books, it will help you understand the schematics and how all the components work together.
    Here is an one just to get you started, youtube is also a great place to learn.
    • layad
      • Nov 2011
      • 244
      Here is an one just to get you started, YouTube is also a great place to learn.
      thank you so much for this file , it helped me a lot,my problem is understanding the big chips data sheet and each pin function!!
      to trace any fault i need to understand the diagram to determine myself where to spot my multimeter
      thank you again
      • Agent24
        I see dead caps
        • Oct 2007
        • 5072
        • New Zealand
        Just had a quick skim through that, it looks quite useful.
        -David VanHorn
        • lezsimply
          The Wanderer
          • 657
          • Philippines
          You can also try this one. Its not that really advance atleast it can help you from scratch.
          • layad
            • Nov 2011
            • 244
            thank you, but i am looking for advanced one, this book will be very helpful for the new ppl in this field , and it will be helpful too if we have sticky topic about those kind of books
            • arun2910
              • Mar 2014
              • India
              Thank you.......
              • arun2910
                • Mar 2014
                • India
                Thank you....
                • kasatmata
                  • Sep 2012
                  • 18
                  • Indonesia
                  Thank you.....
                  • newbieindi
                    • Feb 2014
                    • indonesia
                    Thank you...GBU..
                    • zorro1009
                      • Mar 2012
                      • the philippines
                      thank you man!
                      • zorro1009
                        • Mar 2012
                        • the philippines
                        tahn you man!
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5072
                          • New Zealand
                          I found this interesting thing last night:
                          http://kythuatphancung.vn/loai-tin/mainboard.html
                          Taken from http://www.edaboard.com/thread161775.html
                          You need Google translate or to learn Vietnamese though!
                          -David VanHorn
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • danielgerman681
                            ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                            by danielgerman681
                            Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                            08-27-2025, 01:17 PM
                          • corrize
                            Where to find a very small fpc connector 0.3mm between 2 pins ?
                            by corrize
                            Hello, I search this connector (oxydated).
                            It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                            I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                            I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                            Do you know how to find this connector please ? What is the exact name for find it ?
                            08-06-2024, 05:25 PM
                            Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                            by sam_sam_sam
                            This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                            Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                            07-07-2024, 02:34 PM
                          • madscientist750
                            Replacing electrolytic caps by solid caps on old motherboards
                            by madscientist750
                            I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                            I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                            I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                            10-19-2025, 06:10 AM
