Acdrv not genarating
  • RATIM SIDDIQUE
    • May 2024
    • 7
    • bangladesh
    Lenovo fs44a&fs54a nm-c171 rev:1.0 board
    charging ic bg24780s
    Dc in-19v
    Regn-6v
    Acdetect-2.8v
    Acok low
    No volt in acdrv pin
    laptop running fine with battery
    no power without battery
    help me plz
  • mon2
    • 14657
    Remove all power. Meter in resistance mode.
    Measure the resistance across the DC-in mosfets (full details in the sticky above by @Piernov).
    Measure:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Post each measurement of each DCin mosfet. If ACDRV is low, the fault is likely a defective mosfet which is being driven by this charger pin. In series with ACDRV is often a ~4k ohm resistor. You can flux and carefully remove this resistor. Do not lose the part.
    Then power up again to check if ACDRV is ~25v without this resistor driving the mosfets. Best to check the resistance without power on the same mosfets.
    • RATIM SIDDIQUE
      • May 2024
      • 7
      • bangladesh
      Thank u so much
      pq202 was faulty
      I repalaced it,now working fine
      Again thanks for your advice
      • ResoluteHawk
        Quanta 0P5 (DA0P5HMB8E0-Rev E) Missing ACDRV
        by ResoluteHawk
        I have an HP 15-DY laptop in because the battery is not charging.
        If I use a charged battery, the laptop powers on but the battery will not charge, however the orange charge light does turn on. The laptop loses power as soon as I disconnect the battery.
        I've replaced the BQ247 chip with a known working one and I get the same issue and the same measurements.
        Measurements are as follows:
        BQ728 IC
        VCC (Pin 20) => 19V
        CMSRC (Pin 3) => 0.8V (This is a problem but I can't figure out what's causing the low voltage)
        ACDRV (Pin...
        04-10-2025, 11:36 AM
      • zaurus81
        Asus TUF Gaming F16 (2024) FX607J no power no ACDRV
        by zaurus81
        Hi all, I have a Asus TUF Gaming F16 (2024) FX607J motherboard with liquid damage. The oxide on the board was removed before giving it to me. This made it more difficult to repair. Also they did not give me the power supply.
        When I connect the 20 volts with the bench power supply I get 4.3 volts on the main power line. If I remove the power sensing resistor I get 20 volts on one side (first 2 mosfets are ok) and 4.3 volts on the main power line (see photo). How is this possible?? I thought the 4.3 volts was coming from the battery mosfet so I unsoldered it and tested it. It is ok too. I...
        11-21-2024, 05:04 AM
      • elsomer
        Acer nitro 5 bq24781 no acdrv
        by elsomer
        Hi people, i have an acer nitro 5 with motherboard model gh51m la-k861p , it came with the resistor pr103 blow up, i repaced that resistor, i check the coils plb2, pl301, pl501 and has no short to ground, i conect the charger and it doesnt power at all, i check pqb3 on pin 5 to 8 and its 19v, pin 1 to 4 its 0
        so i repaced, pqb3, pqb4, and makes no change, still no acdrv, i replaced bq24781 and makes no change, still no acdrv, if someone can help pls, thanks, this are the schematic and boardview
        [MOD EDIT] LINK to schematic & boardview -> https://www.badcaps.net/forum...
        04-22-2024, 11:30 AM
      • orientalsniper
        Missing ACDRV in Quanta 0P5D
        by orientalsniper
        Hello all, been trying to diagnose this board all night and haven't been successful, so once again I come here for help.
        Board has a history of being liquid spilled, but I see no corrosion since they brought it to me the day after.
        The DC-IN mosfets don't seem to be shorted (PQ1001 & PQ1002).
        I've replaced the PU1001 (BQ24728) with a BQ24725 with no changes.
        I've also removed PR1020 the 4K resistor connecting the charging IC with the two dc-in mosfets to see if 25V would be present for ACDRV, but I still get 0V....
        02-07-2023, 06:27 AM
      • Zilicon
        pavilion 15 Y11A motherboard low ACDRV signal
        by Zilicon
        Greetings...
        Please, I need help in fixing the above board problem. The board number is DAY11AMB6E0 REV: E.
        0.8V is the voltage that was able to deliver into the system due to ACDRV being stuck at 0.8V. The system works when 19V is introduced to the PQ20 drain, but the battery does not charge.
        Below is the IC's reading when plugged in:
        1. 0.8
        2. 0.8
        3. 0.8
        4. 0.8
        5. 0
        6. 1.6
        7. 0.4
        8. 0.5
        9. 0.5
        10. 0
        11. 1.9
        12. 1
        13. 1
        14. GND
        15. 0
        16....
        04-06-2023, 09:53 AM
