Macbook Air A2337 820-02016 No Power
  • Rezid
    • Mar 2021
    • 8
    • US
    i've got an A2337 820-02016 that has no power. No sign of liquid damage and no obviously damaged components. The board looks brand new. USBc amp meter does not turn on when plugged into either port. I've tried multiple known good chargers and usbc boards. No shorts on any of the large coils. Not super familiar with diagnosing Macbook boards so any help is appreciated.
    USBC1_CC1 = 1.6v but fluctuates to .9v
    PPVBUS_USBC1 = 0v
    PP3v3_UPC1_LDO = 0v
    PPDCIN_AON_CHGR_R = 0v
    PPVBAT_AON_CHGR_REG = 0.07v
    PPBUS_AON = 0.07v
    I'm thinking bad CD3217 but just hoping someone more knowledgeable can help me confirm that.
  • mon2
    • 14256
    Hi. It will help to pick up a USB Type C meter (bidirectional type) to gauge the current draw and the voltage being selected by the power delivery interface (PD). You can get these on Amazon.
    Remove all power. Disconnect the battery. Measure the resistance to ground of PPBUS_AON @ fuse F5200. Measure both sides of this fuse.
    If there is a low resistance to ground then there is a shorted part on this major power rail. Post the measurement in ohms.
    • Rezid
      • Mar 2021
      • 8
      • US
      Hey thanks I've got one already. Screen on there remains black and doesn't show current draw.
      Both sides of F5200 are about 2.7M ohms. Diode mode is .48
      • mon2
        • 14256
        No short there.
        For each CD3217 that is onboard, measure the resistance to ground of each LDO rail. Respectively, when you make use of a type C port, that local CD3217 PD controller must create the local LDO rails. Each CD3217 must be functional to allow for the 20V power delivery contract. We are now checking to see if there is a LDO rail that is shorted.
        Do inspect the contacts of the USB Type C paddle boards which are wear out items. Often we see macbooks in the shop with cat urine or similar substance on the contacts. If in doubt, clean the contacts with IPA (alcohol from Costco pharmacy is great for this) with Q-tips. Better to just replace with a fresh paddle board if available to you. You can check Mobile Sentrix in VA for such parts with short lead time. Otherwise Aliexpress stores.
        If your display on the Type C meter is dark then this implies that even the basic 5 volt rail that is offered upon power up by the power adapter is being shunted to ground. Test that the display is not dark by connecting the meter to the power adapter but do not mate with the logic board. Then the meter should show 5v with 0mA current draw (since there is no real load).
        Review this great webpage if you have not done so already:
        CD3215 Bootup Sequence - LogiWiki
        • Rezid
          • Mar 2021
          • 8
          • US
          I don't know how I missed it as I measured it in diode mode before, but found that PPVBUS_USB1 was shorted. Injected 1v and DF602 lit up under the thermal cam. Removed it and measured PPVBUS_USB1 again and the short was gone. If I replace it with one from a donor board the short comes back. If left empty, the other port attached to PPVBUS_USB0 draws 20v 0a.
          • mon2
            • 14256
            DF602 (TVS2200) is an unidirectional TVS diode so there is a polarity. Be 100% sure that you are placing the replacement in the same orientation as the original. Review the notch on the bellyside of the parts for the key.
            Respectively, it should be possible to test the part before placing onto the board using diode mode. Meter in diode mode. Red meter lead onto the anode (+) = backside of the arrowhead = ground pins on the PCB; black meter probe onto the cathode (-) = signal line to be protected on the PCB.
            • Rezid
              • Mar 2021
              • 8
              • US
              Looks like the DF602 I took from my donor board was also faulty. Swapped it again and everything is working. Thank you for your help.
              • mon2
                • 14256
                Well done!
                • rounin
                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                  by rounin
                  I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                  🛠 Original Issue
                  The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                  04-19-2025, 01:18 AM
                • mkdj
                  MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                  by mkdj
                  About me, my goal and the equipment I (don't) have:
                  I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                  About my issue and my goal:
                  A friend of mine has a MacBook Air M1 A2337 that does not...
                  04-03-2025, 08:28 AM
                • Adogabriel100
                  where to get trusted CD3217. Problem with A2337 Macbook Air
                  by Adogabriel100
                  Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
                  The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
                  09-06-2024, 12:06 PM
                • Skrndelj
                  Apple Macbook Air M1 A2337 Trackpad problem
                  by Skrndelj
                  Hello all,
                  I am repairing a Macbook A2337 and i have a problem
                  The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
                  When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
                  I inspected the whole board and everything seems fine.
                  Can anyone help me as i didn't fiddle with trackpad...
                  06-11-2024, 04:26 AM
                • Patrick501
                  Macbook Air A2337 dead at 5V/0,00A
                  by Patrick501
                  Hey,
                  I'm working on a MacBook Air M1. I'm pretty sure the U8100 is not working correctly. But I never had to change it before, so I wanna ask anyone of you guys to confirm (or not confirm) my thoughts on it.
                  USB Tester: 5V / 0,00A
                  PPBUS_AON: 12,3 V
                  PP5v_S2: 0 V no short
                  PP3v3_S2_UPC: 0 V no short
                  PP1v25_S2: 0 V no short
                  PPDCIN_AON_CHGR_R: 5 V
                  no enable signals for the S2 rails by the U8100
                  both CR3217 (UF400, UF500), are supplied by 5V (Fuses FF200 and FF201)
                  PP3v3_UPC0_LDO: 0 V, 0,5V diode mode to gnd
                  PP1v5_UPC0_LDO_CORE:...
                  11-29-2024, 02:47 PM
