Alienware p18e
  • Ryan Wurtz
    • May 2024
    • 20
    Alienware p18e
    Hello, I have a older Alienware with mobo number, VAS00 LA-9331P REV 1 - - - laptop model is P18E001
    I cannot figure out why the thing won't charge.
    Person who brought it too me was using a hp charger with 19.55v on the middle pin. My Dell 150w Dell charger has nothing I can measure on the middle pin. What voltage should psid have when I have a Dell 150w charger connected? Any obvious place I can start poking around?
    The video shows what psid is doing with the charger connected.
  • mon2
    • Dec 2019
    • 14370
    You cannot use a HP charger to power a Dell laptop. HP uses an analog voltage to define the power adapter rating while Dell uses a 1-wire protocol that was developed by Dallas Semiconductor -> then Maxim and now Analog Semiconductor owns the IP.
    Respectively, the PSID is a parasitic powered design. The EC (8051 / ARM, whatever) stand-alone micro is the bus master and pumps out a communication over this line and the power adapter (must be a Dell) will energize from this low current voltage rail and respond back to the packets.
    It is possible that the line cannot be sampled properly since you have a multimeter and not an oscilloscope.
    Remove all power. Meter in diode mode. Red meter probe, yes red to ground. Black meter probe to the pin to test.
    Test the PSID line in diode mode at inductor PL2. Be sure that the connection from the tips of PL2 reach the actual power connector @ PJPDC1 (pin 2). Also, your DELL power adapter must have a needle like pin in the center of the barrel connector = PSID pin.
    • Ryan Wurtz
      • May 2024
      • 20
      Thanks for the reply.
      I am using a Dell charger now, I told him an hp won't work.
      See the attached images, it's 1 voltage drop. From pl2 to pin 2 on pjpdc1
      • Ryan Wurtz
        • May 2024
        • 20
        Is that expected mon2? Anything else I can measure to figure this out?
        • mon2
          • Dec 2019
          • 14370
          The PSID line does not look to be shorted. Configure the meter into voltage mode. Power up and measure the voltage on this same point of interest. Do you see any voltage on this signal line?
          If not, review the over voltage crowbar mosfet and also the series resistor between the EC pin and the mosfet = ~33R ohms.
          Often this resistor and/or the mosfet become defective. Review the similar fault and thread here on how to proceed. Consider to check the resistor and also remove and bypass the mosfet for testing. The mosfet is present to shut off a high voltage from the power adapter side that can kill the EC microcontroller. Respectively, if the mosfet bypass works for your case, seek out a replacement from Digikey / Mouser or Arrow electronics. If you are not in a rush, Aliexpress is an alternative. Some offer 'fast shipping' which for us in Canada equates to ~2 weeks or so.
          Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00) - Badcaps
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            The first thing to check in case of Dell is whether the adapter is correctly identified or not in bios setup.
            Confirm whether the adapter is shown as "Unknown"
            • Ryan Wurtz
              • May 2024
              • 20
              Sorry for the slow responding.
              the voltage fluctuates from 0.1 to 0.3, i will attach a video(20240824_224622_1.mp4)
              PQ1 is not present on this board.
              PR14 powered= 5.1v
              PR8 powerered= 5.1v
              PR8 not powered= 10k ohm
              pr14 no power= 99.3k ohm
              i will attach the schematic and board view i am using.
              i have the board on the table now, the error message at boot was, hq720.jpg that picture i attached except it was asking for a 180w adapter.
              does that mean it isnt recognized? and i should be looking into getting a new higher watt adapter?
              Link to schematic --> https://www.badcaps.net/forum/troubl...331p-schematic
              • rogfanther
                • Jul 2006
                • 458
                • Brazil
                That picture shows the adapter was not recognized. Was it taken with the HP charger ? You need a original Dell one, with the PSID circuit working for the machine to detect and accept the charger.
                • Ryan Wurtz
                  • May 2024
                  • 20
                  I have tried with a hp the customer brought it in with, then I tried an original Dell 65w, then I tried what I think is an original Dell 130w.
                  I would at least have though it would charge with the two dell chargers but maybe throttle the performance.
                  • rogfanther
                    • Jul 2006
                    • 458
                    • Brazil
                    But what does BIOS show with the Dell chargers ? Does it show the wattage of them ?
                    • Ryan Wurtz
                      • May 2024
                      • 20
                      I will re assemble and report back.
                      • Ryan Wurtz
                        • May 2024
                        • 20
                        OK, So the 90w adapter is detected fine, the battery in the bios it says is working fine, but in windows the battery is at 0% and not charging.
                        based on the error message the battery should charge with the 90w adapter.
                        the 120w adapter i have is not detected. so might be faulty or not genuine.​
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          You simply cant power up a gaming PC with under rated power adapter.
                          • rogfanther
                            • Jul 2006
                            • 458
                            • Brazil
                            Actually, the error message says you have a 90W adapter connected, but the computer needs a 180W one, and asks for you to use one.
                            Maybe with the machine off the battery could charge with the 90W adapter, but when running, since it is half of what the machine wants, it is luck if it works throttled. You will need a correct adapter to make diagnoses , or you may be hunting ghost issues.
                            • Ryan Wurtz
                              • May 2024
                              • 20
                              i have order a 180w. i will see if it gets detected and if anything changes.
                              • Ryan Wurtz
                                • May 2024
                                • 20
                                i feel silly, I should have bought a 180w adapter from the start like i planned.
                                the laptop is charging fine, everything seems good. Thanks for the help everyone!
                                • exerion5000
                                  DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
                                  by exerion5000
                                  Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
                                  below normal, as if it were operating in an extreme energy...
                                  10-15-2023, 02:12 PM
                                • BTubbs200
                                  Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                  by BTubbs200
                                  Dell Latitude 5420 P137G
                                  Board: LA-K491P REV A01
                                  I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                  Board seems to have no shorts, all power rails are fine and show high resistance.
                                  When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                  01-24-2025, 08:15 PM
                                • Johndill
                                  Dell Inspiron 7567 LA-D993P odd charger issue
                                  by Johndill
                                  Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                  There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                  I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                  Here are the tested scenarios:
                                  1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                  2. With the laptop off, plug in charger (LED says on) & the front charging...
                                  11-16-2022, 10:55 PM
                                • reessi
                                  Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                  by reessi
                                  Hello:
                                  I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                  I started on the ACER:
                                  Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                  All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                  I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                  10-29-2024, 11:31 AM
                                • Bowline
                                  by Bowline
                                  06-11-2025, 10:13 AM
