Lenovo Ideapad 330-14IKB - No Power
  • Sofian75
    • Aug 2023
    • 87
    • France
    Main power rail is present but 3.3v alw isn't there and I don't have any voltage at the coil on the 5v rail either.
    Trying to focus on the 5v rail first, I don't understand why I have the 5v at the resistance and the input of the capacitor but not at the output (in red).
    I ve already changed the capacitor but same thing.
    What am I missing?
  • DeXXter
    • Aug 2023
    • 112
    • Chile
    I quickly checked the datasheet and those 5v you have there are the VCC line, that's for internal stuff of the chip itself, so don't focus on that. That ic is apparently fine, you don't have voltage on that coil because the laptop is not turning on, check the EC if the pwr_btn is working properly.
    • FZG
      • Sep 2022
      • 117
      The cap side you labeled 0V in red is the ground side. If there is a connection from there to the coil you may have a short somewhere downstream.
      • piernov
        • Jan 2016
        • 4439
        • France
        This is the bootstrap circuit of the buck converter, the capacitor C6006 does not connect to ground, it does connect to the phase line if the buck converter, before the inductor.
        5V is normal on the bootstrap pin as there's an internal diode between the internal 5V LDO and this pin inside the IC.
        • Sofian75
          • Aug 2023
          • 87
          • France
          Aren't the 5 and 3.3v rails supposed to be always on?
          • DeXXter
            • Aug 2023
            • 112
            • Chile
            Sure, but it looks like the laptop is not reaching that state. Apparently u only have 3.3v LDO, so before going to the 5vAlW check if you have those 3.3v on the kbc. Also check the resistance on those coils (specially 3.3v since the kbc gets is power from this) and if you have something when pressing the power button.
            Also I would check that EN pin, what do u got there?
            • Dr.d
              Help please..Lenovo ideapad 5 14itl05 power and charging problem
              by Dr.d
              I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
              Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
              04-05-2024, 11:48 AM
            • gleniu
              Lenovo IdeaPad Gaming 3 15ACH6 - no power
              by gleniu
              Hi, I have a problem with a Lenovo IdeaPad Gaming 3 15ACH6 laptop. My nephew asked me to replace the charging port because the laptop wasn't charging. This issue had happened in the past, so I knew that replacing the port was only a matter of time. Until now, my nephew managed to deal with the problem using a temporary solution: bending the positive metal tabs inside the port with a thin tool. However, this had stopped helping for a while. Today, I replaced the port – and to my surprise, after the replacement, nothing happens when I plug in the charger: the power LED doesn't light up, the laptop...
              Today, 01:13 PM
            • mrfree2ita
              Lenovo T14 gen1 no power, 9v on power rail instead on 15v
              by mrfree2ita
              I'm trying to fix a Lenovo T14 Gen1 laptop motherboard I bought to replace the dead one in mine
              If I plug the usb-c charger nothing seems to happen. The LED stays off and pressing the power button doesn't have any effect. I'm attaching an excerpt of the schematics with my measurements in green.
              I made some measurements on the board (I also read the nice guide I found in this forum for ideas):
              • The 20v reach the charging circuit, and thus I'd say that the voltage is correctly negotiated.
              • The total current sensing line measures about 10 ohm and
              08-30-2024, 11:27 AM
            • rabsonnjala
              LENOVO IDEAPAD 100 works only on bench power supply
              by rabsonnjala
              Hie I have a Lenovo laptop
              Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
              it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
              below are my readings
              with the original charger only
              JBATT1
              PIN1 0.22V
              PIN2 0.22V
              PIN3 0.45V
              PIN4 0.45V
              PIN5 O.43V
              PIN6 0V
              PIN7 GND
              PIN8...
              11-20-2021, 08:32 AM
