NM-c871 in need of re=7c T32
  • omgitdrifty
    • Aug 2024
    • 16
    Hello
    I'm in need of assistant in finding a replacement for RE=7c T32 for nm-c871 .
    Anyone have information please share to help me save this laptop.
    Many Thanks
    David
    • 21841
    Originally posted by omgitdrifty
    Hello
    Many Thanks
    David
    https://www.badcaps.net/search?q=RE%...%22RE%3D%22%7D
    • omgitdrifty
      • Aug 2024
      • 16
      but RT6585C is for RE=6H will it still work?
      David
        • 21841
        David
        Yes,it will be ok, 6H is part of the date code. Here`s the datasheet https://www.richtek.com/assets/produ...DS6585C-02.pdf
Name:	RE= Marking.jpg
        • mon2
          • 14657
          Yes. Only the ‘RE=‘ is the part number. The rest is the manufacturer’s date code of the chip production.
          • omgitdrifty
            • Aug 2024
            • 16
            ahhh ok thanks
            • omgitdrifty
              • Aug 2024
              • 16
              so I use that chip but like a prat I didn't take old one off to see if the short was gone I followed the short and it went all the way to GPU so I called it.
              • KYBOSH
                Trying to Save - Samsung UN55JS6500 - A line down the screen + Falling LED diffusers
                by KYBOSH
                Picked this one up today.
                In addition to falling LED diffusers there is a single line here that maybe a deal breaker.
                From my reading on these boards it is said that the issue is likely a sign of failed tab drivers, ribbons or tab bonding to the panel.
                Wanted to get a 2nd opinion from you guys before I gave up the ghost.
                Great looking TV otherwise.
                Is there any tricks I can do to try to save this one?
                If so, i'll gladly order a set of backlights and save this one from the landfill..
                Thanks in advance
                10-04-2024, 11:00 PM
              • DrDos
                Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                by DrDos
                Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                08-08-2025, 03:16 AM
              • fixitforfree
                Samsung TV mu6179 with Mainboard BN41-02568B wont save configuration.
                by fixitforfree
                I have two Boards BN41-02568B for a UE55MU6179 of which one does produce a good picture (Board A) but can not save its configuration (even a factory reset will not work) and one board which produces a distorted picture (Board B). Learning from here the IC1604 saves the configuration of such a TV.
                Before replacing the IC1604 from Board B to Board A - would that actually solve the problem from Board A not being able to store its configuration or could there be something else wrong with writing to the flashrom? Is it even the right chip to replace or should I look out for a different...
                07-21-2025, 09:07 AM
              • Conste
                Clevo W25CEW doesn't save Bios settings / shutdown issue
                by Conste
                Hello together,
                I have a Clevo W25CEW (Terra 1541) with some strange symptoms:
                1. I cannot save Bios settings by pressing "save settings" in the bios. By pressing "save & exit" it will save the settings.
                2. I can boot normally (UEFI installation), but when I shut the machine down and start it after a few seconds again it will show resume from hibernation and shutdown after POST, just before windows would boot. Then it will go back to factory settings and my UEFI installation will not boot!
                Already changed the CMOS battery...
                09-01-2021, 10:34 AM
              • arif3203
                Dell cant save service tag inspiron 5400 All IN One
                by arif3203
                Please help me,Dell inspiron 5400 with service tag: 46KRF92 cant save service tag eror 8AC6D992,Test with other file same cant save service tag...
                01-05-2023, 04:38 AM
