Red MI 5 no image
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    Red MI 5 no image
    please help me find the problem! no picture on the screen! new display didn't solve the problem
  • AquaMan Ua
    Problem with PANASONIC CF53 laptop after changing BIOS settings
    by AquaMan Ua
    Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
    05-17-2025, 09:40 AM
  • theone111
    by theone111
    3. Problem: TV shuts down
    07-22-2024, 10:36 AM
  • janos6662000
    Philips 47PFS7509/12 LCD TV problem
    by janos6662000
    Hi
    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
    When i applied cable signal to check image, i had normal picture, but TV was restarting.
    I downloaded original firmware and applied the update, but the problem remained.
    From a colleague i received a "factory package software" which is a lot bigger.
    I made another firmware update, but still did not solve the problem.
    Somewhere on the way the error got worse, because at the moment the...
    08-12-2025, 12:54 PM
  • Roman555
    Lenovo Y540-15IRH internal graphics problem
    by Roman555
    Hi there! I need some help or piece of advice.
    A friend of mine kindly asked me to look into his notebook because I have some necessary experience. It's NM-C221 rev 2. A schematics and a boardview I've already downloaded here. Thanks!
    Preface: The notebook was in a professional workshop years ago where some job was done, some bios image was flashed and original backup image was lost. So all this time the notebook has been working using discrete graphics with unknown bios image (but someway compatible, because it was updated by a Lenovo utility).
    Problem:...
    07-05-2023, 07:46 AM
  • doorzon
    AOC AGON AG273QCG refresh problem picture shifts
    by doorzon
    hopefully someone on this board has an idea on how to begin with troubleshooting this problem.
    The monitor AOC AGON AG273QCG (curved 27" QHD monitor) has problems refreshing every 1 to 2 seconds or so. A line appears in the middle of the screen and the lower half of the screen is shifted to the right.
    See attached picture.
    I am leaning towards an issue with bad soldering of the graphics chip, because the problem used to go away after some time (minutes) but now it is here to stay.
    However, this could also be related...
    08-12-2023, 02:36 AM
