A1990 DEAD
  • Arshad alam4659
    • Aug 2020
    • 157
    • India
    now 20v ok but no power same condition
    • mon2
      • Dec 2019
      • 14766
      How did you achieve 20v? What is the current draw?
      Voltage of ppbus_g3h? Does DFU work?
      • Arshad alam4659
        • Aug 2020
        • 157
        • India
        i am trying to dfu mode board is on but no image and some errors in dfu mode
        pls help whats problem and how to solve
        • Arshad alam4659
          • Aug 2020
          • 157
          • India
          anyone know this problem help
          • mon2
            • Dec 2019
            • 14766
            Read the last 2 posts here:
            https://forums.macrumors.com/threads...dlock.2293187/
            • Arshad alam4659
              • Aug 2020
              • 157
              • India
              #26
              Originally posted by mon2
              i,ve tryied but not result
              • master_haze86
                A1990 820-01814-A dead not charging - need help with diagnostics.
                by master_haze86
                Good day everyone,
                Let me preface this with letting you know that I have a smalltime computer repair shop but do not have a lot of experience when it comes to board diagnostics. I am good at soldering etc but finding the issue if there isn't an obvious burnt component is not my strong suit.
                The other day I got a customer come in with a macbook A1990 (motherboard 820-01814-A) that would not turn on and had previously been getting the warning message that the battery needed servicing. (Most folks seem to ignore that message, just like the check engine light in vehicles.)...
                09-13-2025, 06:01 PM
              • thedirekter
                A1990 Dead, Odd Voltages on USB-C, Nothing on AWAKE's
                by thedirekter
                Hey all,
                Been lurking for a while to find a solution to my dead A1990 (board # 820-01326-05, I can't find a bv for that one so I've been using 820-01041 for reference) but have come up empty handed. I haven't really done any diagnostics on electronics like this though so I'm sure I've probably missed something. I've soldered and diagnosed keyboards and cars but this is definitely new to me.
                My overview thus far:
                After browsing the web one night, I closed the lid while it was on the charger, left it on my desk overnight and it was dead in the morning. No response...
                01-02-2024, 11:32 AM
              • Cemal Odabasioglu
                MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                by Cemal Odabasioglu
                I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                Observations...
                01-14-2025, 03:54 PM
              • robka
                MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                by robka
                my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                After that the Macbook was dead. It isn't charging anymore.
                The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                03-02-2024, 02:58 PM
              • silver60618
                Macbook Pro A1990 - Battery not detected after connector torn off
                by silver60618
                Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
                Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
                11-12-2025, 06:36 PM
