i got this blue screen messege everytime turn on the laptop...i try to change new ssd and reinstall windows but the problem still persist...bsod An unexpected I/O Error
Asus X505Z wont boot windows
Try loading windows 10 or 11 on another laptop and then put it back in this machine. Does it go to windows?Comment
Test with another known good SATA cable.
Test with other known good RAM.
Test with a bootable USB media that is loaded with a distribution of Linux. Can that load ok? If yes, then the fault is between the SATA controller / wiring / power to this bootable media.Comment
linux can load sirComment
Disable VMD in bios settings or install RST drivers https://www.asus.com/support/faq/1044458/Comment
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
Channel: BIOS Requests ONLY!
by Stanley1843I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11. I saw the message (Reboot and select a proper Boot device).
I made a bootable USB windows 11 and I run the below commands on the cmd but with no succeed.
DISM /Online /Cleanup-image /Restorehealth
The DISM.... command shows me the error 87.
sfc /scannow
chkdsk
bootrec /FixBoot
bootrec /ScanOs
bootrec /RebuildBcd
For some reason it writes(Total identified installations 0) like there no...-
by DynaxSCHi,
I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
The behaviour is also really very strange, i.e.:- The disk shows always up in BIOS - so it is recognized, so far so good
- POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
by futadmytroAsus g713qm-es94 stuck on boot bios problem
sn^M4NRKD02753616E
MB- g533-6050a3250201-MB-A03
Stuck on boot after ROG logo, did not enter to bios
In flash bios , laprop boot but have video issue
orig bios...-
06-25-2025, 08:07 AM -
by 0xxHi folks,
My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
I assumed that Windows Update was interrupted due to closing... - Loading...
