Asus X505Z wont boot windows
  • dqtech
    Badcaps
    • Jul 2018
    • 639
    • N/A
    i got this blue screen messege everytime turn on the laptop...i try to change new ssd and reinstall windows but the problem still persist...bsod An unexpected I/O Error
  • dqtech
    Badcaps
    • Jul 2018
    • 639
    • N/A
    upp
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Try loading windows 10 or 11 on another laptop and then put it back in this machine. Does it go to windows?
      • dqtech
        Badcaps
        • Jul 2018
        • 639
        • N/A
        already done this but still not boot to windows...will appear same bsod error sir
        • mon2
          • 14659
          Test with another known good SATA cable.
          Test with other known good RAM.
          Test with a bootable USB media that is loaded with a distribution of Linux. Can that load ok? If yes, then the fault is between the SATA controller / wiring / power to this bootable media.
          • dqtech
            Badcaps
            • Jul 2018
            • 639
            • N/A
            linux can load sir
              • 21841
              Disable VMD in bios settings or install RST drivers https://www.asus.com/support/faq/1044458/
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • Stanley1843
                Windows 11 disk no boot
                by Stanley1843
                I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11. I saw the message (Reboot and select a proper Boot device).
                I made a bootable USB windows 11 and I run the below commands on the cmd but with no succeed.
                DISM /Online /Cleanup-image /Restorehealth
                The DISM.... command shows me the error 87.
                sfc /scannow
                chkdsk
                bootrec /FixBoot
                bootrec /ScanOs
                bootrec /RebuildBcd
                For some reason it writes(Total identified installations 0) like there no...
                10-18-2025, 04:41 AM
              • DynaxSC
                ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                by DynaxSC
                I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                The behaviour is also really very strange, i.e.:
                • The disk shows always up in BIOS - so it is recognized, so far so good
                • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                02-23-2025, 01:33 PM
              • futadmytro
                Asus g713qm-es94 stuck on boot bios problem
                by futadmytro
                sn^M4NRKD02753616E
                MB- g533-6050a3250201-MB-A03
                Stuck on boot after ROG logo, did not enter to bios
                In flash bios , laprop boot but have video issue
                orig bios...
                06-25-2025, 08:07 AM
              • 0xx
                2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                by 0xx
                Hi folks,
                My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                I assumed that Windows Update was interrupted due to closing...
                09-14-2025, 03:46 PM
