Macbook Air A1932 Does not Turn ON
  • Dark_
    • Apr 2023
    • 12
    • Países Bajos
    Hello fellas!,
    I have this macbook air with water damage, board 820-01521
    After cleaning the board and checking for possible damage I can't find anything unusual, I'm a bit of a newbie and maybe my question is obvious to many although I haven't found much more info.
    After measuring all the power rails I find the following losses PPVCC_S0_CPU and PPVCCGT_S0_CPU, the chip that controls them is the U7100 and if it is providing the rail of PPVCCSA_S0_CPU.
    The signals CPUVR__PGOOD, CPU_VR_EN are OK.
    Although CPU_VIDALERT_L is low and I see no activity in the SDA and SCLK of this chip.
    On the other hand measuring the rest of signals that comes to my head I find PLT_RST_L signal low all the time, measuring this line gives me 0.700 a little higher than the 0.500 that I have found as reference.
    I also see some activity in the Soc Rom U4770.
    I could understand that by keeping the PLT_RST_L signal all the time, at the end the U7100 receives the alert so it doesn't launch the Vcore and VGT rails
    Any extra idea what I can test ?.
    Thanks for any help guys!!
  • Dark_
    • Apr 2023
    • 12
    • Países Bajos
    UP!
    • mon2
      • Dec 2019
      • 14669
      What is the voltage to ground of PPBUS_G3H?
      What is the voltage and current draw showing on the USB type C meter (if available)?
      • Dark_
        • Apr 2023
        • 12
        • Países Bajos
        PPBUS_G3H is 12.6v and the voltage is 20v 110mA. I replaced U7100 and recover signal CPU_VIDALERT_L 1.8v.
        However PLT_RST is 0v permantely.
        • mon2
          • Dec 2019
          • 14669
          What is the voltage to ground of ALL_SYS_PWRGD_R?
          • Dark_
            • Apr 2023
            • 12
            • Países Bajos
            ALL_SYS_PWRGD_R is 1.8v.
            U7100 activate PPVCCSA_S0_CPU but not the other two lines PPVCC_S0_CPU and PPVCCGT_S0_CPU
            PLT_RST_L permanently 0v, in diode mode I've got 0.700
            • mon2
              • Dec 2019
              • 14669
              Remove all power. What is the resistance to ground of the following?
              PPVCC_S0_CPU
              PPVCCGT_S0_CPU
              PPVCCGT_S0_CPU
              is the GPU rail which may not be on if it is not required. Not sure.
              ..confirmed:
              820-00928 No GPU | Rossmanngroup Forums
              • Dark_
                • Apr 2023
                • 12
                • Países Bajos
                Resistante to ground from those lines :
                1. PPVCC_S0_CPU : 15.5
                2. PPVCCGT_S0_CPU : 13
                3.
                PPVCCSA_S0_CPU : 28
                • mon2
                  • Dec 2019
                  • 14669
                  The rails are not shorted but not on.
                  Try a DFU.
                  • Dark_
                    • Apr 2023
                    • 12
                    • Países Bajos
                    I could not go more futher since I've got the following error Image attached
                    The System cannot be restored on this device. Gave up waiting for device to transition from DFU state to DFU state. [com.apple.MobileDevice.MobileRestore
                    • 0xFCA (4042)]
                    • bouch
                      unlock macbook air A1932 2019
                      by bouch
                      hi
                      i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                      i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                      i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                      have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                      I need help or information?
                      Does anyone have the minat2 activator 1.4 software?
                      Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                      Thank yo...
                      03-12-2025, 10:14 AM
                    • nikolayu
                      MacBook Air A1932 internet recovery loop
                      by nikolayu
                      I have A1932 that is going to internet recovery every time.
                      i tried nvram and smc reset but it looks that MacBook is not reacting to that.
                      i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
                      keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
                      also won’t open option to boot from usb device.
                      and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
                      07-22-2025, 02:55 AM
                    • TOMÁŠ
                      MacBook Air A1932
                      by TOMÁŠ
                      Hi, I've never worked with a MacBook before, so I need some advice.
                      I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
                      05-20-2025, 11:19 AM
                    • Arshad alam4659
                      macbook air a1932 sign out of find my
                      by Arshad alam4659
                      Today I receive a MacBook Air A1932, its apple ID has been deleted but when I am resetting it is showing a message(sign out of find my ) customer's have no apple id he bought this MacBook from someone else can someone help me remove this message...
                      04-09-2025, 12:37 AM
                    • astroboypaul
                      Macbook A1932 Some Keys Not Working
                      by astroboypaul
                      Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
                      Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left...
                      06-10-2024, 05:32 AM
