Macbook Pro M1 a2338 (820-02020) - 5V 0A
  • obelix24
    • Jun 2023
    • 291
    • Slovakia
    Hi all just got another Macbook Pro M1 a2338 that is taking only 5V 0a on both USB-C ports.
    I've checked and firstly there was 5V 0,4a and after checking with thermal camera i found it was C81DB that was shorted after removing and replacing with new cap short was gone but i get only 5V 0a.
    PPBUS_AON is 12,3V
    I've checked according to repair wiki all 4 resistors (R5221, R5222, R5261, R5262) all were 1,1ohm so i've replaced U5200 but still the same problem only 5V 0a
    Any idea ?
  • mon2
    • 14021
    Perform a thermal camera scan.
    Try a DFU.
    [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020 - Badcaps
    • obelix24
      • Jun 2023
      • 291
      • Slovakia
      I've tried thermal camera but as there is 0a nothing is gettin hot. If it will be in DFU there will be atleast some amp consuption.
      • obelix24
        • Jun 2023
        • 291
        • Slovakia
        Any idea what to check ?
        • obelix24
          • Jun 2023
          • 291
          • Slovakia
          I've tried in known good case and i'm still getting only 5V 0A ...
          tried to put it in DFU but nothing it still remains on 5V 0A ... other macbook pro with M1 is at least turning on / off (i can see it that usb meter is turning on and off) but on this one it's still on 5V 0A ...
          • obelix24
            • Jun 2023
            • 291
            • Slovakia
            Ok got it fixed it was bad solder joint under U8110 after resoldering i got 20v charging fine and turned on
            • mon2
              • 14021
              Excellent find!
              • sdogs
                macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                by sdogs
                Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                06-27-2025, 01:58 PM
              • sdogs
                by sdogs
                06-27-2025, 11:26 AM
              • classicandy
                MacBook Pro A2338 [820-02773] No Audio (Speakers and Microphone)
                by classicandy
                Hi Everyone,
                Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
                UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless ​a...
                04-14-2024, 12:00 PM
              • User555111
                A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
                by User555111
                Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
                02-05-2024, 08:16 AM
              • Schluchti45
                MacBook Pro M2 A2338 with PowerSupply it is running, "X" on the battery symbol and FAN is running permanently
                by Schluchti45
                I have a MacBook Pro A2338 M2. The MacBook runs with the power supply unit. The fan runs permanently and the battery shows the message “Service recommended”.
                I have already replaced the battery with a new one, but this has not helped. I have also tried DFU and the system restored the error remains the same.
                Do any of you have any ideas where I could look or how I should proceed here?...
                10-22-2024, 11:42 AM
