MacBook Pro 2020 A2251 (820-01949) No Backlight
  • pcmacdoctors
    • Jul 2019
    • 7
    • england
    Hello, I have an A2251 MacBook Pro logic board (820-01949) with an unknown history and no signs of liquid damage. I'm trying to make use of it. The computer boots up and works normally, except there is no backlight on the screen and the camera is not working. An external display works fine.
    I swapped the display and display cable with known working ones, but there was no change.
    Upon inspecting the board, I found that L8504 was blown. I replaced it and the adjacent components (C8504, CC727). Now the camera works. I also replaced C8440 near U8400, as it looked like it might have been knocked. It seems okay, with a reading of ~5V from pin 1.
    While the camera now works, the backlight is still not functioning. There is no short to ground on PPVOUT_LCDBKLT. All those capacitors look fine, they are not getting hot, but no voltage seems to be going through them either. The F8400 fuse works, with a continuity test showing a voltage reading of ~12.6V on both sides, which I believe is correct.
    no voltage on either side of L8410 and I've replaced that also.
    I can't detect any short to ground on the EDP lines of the display connector.
    R8442 has no voltage on pin 1 or 2. According to Repair.wiki, this suggests a problem with U8400 and/or the CPU.
    I swapped over U8400 also and still doesn't work.
    I found that really tough to do and although it looks pretty good I might have failed to swap it properly.
    I suspect it's U8400 as the computer works fine otherwise. Is there anything else I should try?
  • mon2
    • 14659
    Do you see graphics on the LCD display? Test with a phone torch from the front of the LCD.
    Measure the voltage to ground of IPD_LID_OPEN.
    • pcmacdoctors
      • Jul 2019
      • 7
      • england
      Hah I should have checked that. It actually doesn't look like it does, I cant see Apple logo under the torch.
      IPD_LID_OPEN reads as 1.79v.
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
        🛠 Original Issue
        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • capon5153
        Macbook A1706 works perfectly but no data on USB C
        by capon5153
        hello,
        so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
        i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
        06-22-2025, 09:42 AM
      • MikoMiko
        MacBook Pro A2251 - 820-01949-A not charging
        by MikoMiko
        Hello everyone, I have a MacBook Pro 13” 2020 (Four ports) (Model A2251 with the 820-01949-A logicboard). It had some minor liquid damage but I carefully cleaned the logic board with alcohol and let it dry as needed. Now I encounter following situation: The MacBook does start but the Battery is not charging when a cable is plugged in any of the ports (I use the powerbrick and cable that came with the device). It had some charge left, so I could safe some data, but I was limited my the 13% and the speed of airdrop. The liquid-damage is almost only limited to the side of the logic board where...
        03-24-2025, 11:09 AM
      • CAPTGENE
        A2179 Macbook Air turns ON and works normally with a battery but it is not charging
        by CAPTGENE
        I have similar a similar issue. My A2179 Macbook Air turns ON and works normally with a battery but it is not charging. With the USC-C alone it takes 20V but only 100mA, PPBUS is 12.3Volts, and wont turn ON.
        I replaced U7000 twice with the same result. not charging!
        Whats should I check or replace?
        02-20-2025, 02:58 AM
      • envym
        by envym
        Hi everyone!
        06-27-2025, 08:54 AM
