HP DV6000 DA0AT6MB8E2 no power led flashes half second
  • Dimitrios
    • Nov 2013
    • 127
    • Greece
    Hello, I have HP DV6000 DA0AT6MB8E2 Rev: E motherboard and experiencing a short 25Ω on 1.05V rail which is mostly MCH power voltage.
    Symptoms: As soon as I press power button led lights up and immediately closes and powers off.
    I have replaced nvidia GPU with a new one, reflowed MCH 945 but still same symptoms.
    Also removed PQ33, PC34 and PC33 (PC32 is already missing) but still that rail is shorted. What do you think? Should I replace Intel 945 MCH?
  • dj_ricoh
    • 2073
    Re: HP DV6000 DA0AT6MB8E2 no power led flashes half second
    PQ30 out and PQ33 and remove PL23.
    do you still have short on the PQ pads?
    • Dimitrios
      • Nov 2013
      • 127
      • Greece
      I haven't removed PQ30 because on pins 5-8 there is 19V VIN so that line is correct. I haven't removed the coil PL23 yet, wouldn't that cut the circuit in half?
      . However I have already completely removed PQ33 but short remains.
      • dj_ricoh
        • 2073
        you need to remove the coil to see if the short goes in the line.
        then you can check if the pq pads are ok.
        that max its ok? PU7
        • Dimitrios
          • Nov 2013
          • 127
          • Greece
          You are right because +1.05V signal gets to some big 330UF caps near CPU and some small caps under CPU and also is the main power supply for MCH 945. I need to remove the coil to see if it stills has the line a shortage. And I will also check thoroughly PU7.
          • dj_ricoh
            • 2073
            the problem i don`t know and will really like to know what is the purpose for those pins.
            like what each pin does
            • dj_ricoh
              • 2073
              PU7. some i can see like VDD supply ,DL1 gate DH1
              • Dimitrios
                • Nov 2013
                • 127
                • Greece
                Removed coil PL23 and the short goes on the right side of the coil to PC34, PC33 etc.
                PU7 MAX 8743EEI+ has (with coil removed):
                VCC: 5V
                VDD: 5V
                V+: 19V
                PGOOD: 0V (NOT grounded)
                DH1: 1.9-3.3V Variable ? Gate of PQ30
                DL1: 0V GND Gate of PQ33
                LX1: 2.3V path to coil PL23 is not shorted now that it has been removed.
                • Tiagho
                  • Feb 2014
                  • 10
                  • Brazil
                  I need this schematic please DA0AT6MB8E2
                  • drdyzio
                    • Apr 2014
                    • 74
                    this might be it its all i could find
                    • odie34
                      Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                      by odie34
                      I am a hobbyist (not a professional) so please be gentle...
                      I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                      I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                      02-18-2024, 09:11 AM
                    • Raulnn
                      TD Systems K50DLG12US half black and half white screen
                      by Raulnn
                      good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                      By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                      01-20-2024, 04:49 PM
                    • lcdcaps1
                      HP DV6000 DA0AT6MB8E2 Rev: E, boardview
                      by lcdcaps1
                      Hi
                      All
                      Does anyone have a boardview please for
                      Many Thanks in advance
                      11-06-2020, 04:41 PM
                    • dicky96
                      Bang & Olufsen (HP) Omen Laptop power light flashes once but no boot
                      by dicky96
                      Hi guys
                      I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
                      If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
                      If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time...
                      03-24-2023, 06:33 AM
                    • ravi_1617
                      Da0at6mb8e2 dv6000
                      by ravi_1617
                      Hi.Yes Quite old .
                      Problem U21 ICS954206AG-T GEN ,ic heating a lot .Already replaced no improvement .Where to start from.
                      Thanks...
                      09-14-2020, 12:01 PM
