HP DV6000 DA0AT6MB8E2 no power led flashes half second
  • Dimitrios
    • Nov 2013
    • 127
    • Greece
    Hello, I have HP DV6000 DA0AT6MB8E2 Rev: E motherboard and experiencing a short 25Ω on 1.05V rail which is mostly MCH power voltage.
    Symptoms: As soon as I press power button led lights up and immediately closes and powers off.
    I have replaced nvidia GPU with a new one, reflowed MCH 945 but still same symptoms.
    Also removed PQ33, PC34 and PC33 (PC32 is already missing) but still that rail is shorted. What do you think? Should I replace Intel 945 MCH?
  • dj_ricoh
    • 2073
    • uk
    Re: HP DV6000 DA0AT6MB8E2 no power led flashes half second
    PQ30 out and PQ33 and remove PL23.
    do you still have short on the PQ pads?
    • Dimitrios
      • Nov 2013
      • 127
      • Greece
      I haven't removed PQ30 because on pins 5-8 there is 19V VIN so that line is correct. I haven't removed the coil PL23 yet, wouldn't that cut the circuit in half?
      . However I have already completely removed PQ33 but short remains.
      • dj_ricoh
        • 2073
        • uk
        you need to remove the coil to see if the short goes in the line.
        then you can check if the pq pads are ok.
        that max its ok? PU7
        • Dimitrios
          • Nov 2013
          • 127
          • Greece
          You are right because +1.05V signal gets to some big 330UF caps near CPU and some small caps under CPU and also is the main power supply for MCH 945. I need to remove the coil to see if it stills has the line a shortage. And I will also check thoroughly PU7.
          • dj_ricoh
            • 2073
            • uk
            the problem i don`t know and will really like to know what is the purpose for those pins.
            like what each pin does
            • dj_ricoh
              • 2073
              • uk
              PU7. some i can see like VDD supply ,DL1 gate DH1
              • Dimitrios
                • Nov 2013
                • 127
                • Greece
                Removed coil PL23 and the short goes on the right side of the coil to PC34, PC33 etc.
                PU7 MAX 8743EEI+ has (with coil removed):
                VCC: 5V
                VDD: 5V
                V+: 19V
                PGOOD: 0V (NOT grounded)
                DH1: 1.9-3.3V Variable ? Gate of PQ30
                DL1: 0V GND Gate of PQ33
                LX1: 2.3V path to coil PL23 is not shorted now that it has been removed.
                • Tiagho
                  • Feb 2014
                  • 10
                  • Brazil
                  I need this schematic please DA0AT6MB8E2
                  • drdyzio
                    • Apr 2014
                    • 74
                    this might be it its all i could find
                    • odie34
                      Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                      by odie34
                      I am a hobbyist (not a professional) so please be gentle...
                      I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                      I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                      02-18-2024, 09:11 AM
                    • Raulnn
                      TD Systems K50DLG12US half black and half white screen
                      by Raulnn
                      good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                      By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                      01-20-2024, 04:49 PM
                    • lcdcaps1
                      HP DV6000 DA0AT6MB8E2 Rev: E, boardview
                      by lcdcaps1
                      Hi
                      All
                      Does anyone have a boardview please for
                      Many Thanks in advance
                      11-06-2020, 04:41 PM
                    • scubacamper
                      Sharp Aquos LC-70C6400U Half Screen Dark
                      by scubacamper
                      I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                      Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                      when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                      05-03-2025, 12:19 PM
                    • cajoeg
                      Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                      by cajoeg
                      Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                      The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                      02-10-2025, 04:01 PM
