Lenovo X240 - motherboard VIUX1 NM-A091
  • vince59
    • Nov 2017
    • 46
    • italy
    Hi all, due to a mistake a friend connected a wrong USB pin to the laptop. The laptop immediately stopped running and never get back to normal functioning.
    If I connect to the power supply the only sign that I have is three blink forn the power button and in accordance with user manual this only means that a power supply has been connected. With battery no signs at all. My understanding is some hw problem to the mb. The laptop is an old one but still working so I wonder if it is worth to repair or buy a new mb for 25/30 USD. Does anybody have suggestions what to to or check before throwing into the garbage bin?
  • Sephir0th
    • Oct 2020
    • 1289
    Explain what do you mean with "wrong USB pin", please
    FairRepair on YouTube
    • vince59
      • Nov 2017
      • 46
      • italy
      Ok let me explain. We had to connect a USB cable from an automotive dash to the laptop for diagnosis. Unfortunately my friend connected the USB cable to the wrong dash connector. When I plugged the USB cable to the USB port the laptop died. To give a full picture, I did not check the connection so I went straight to the connection. I used my laptop (HP ELITEBOOK 820) and the laptop "died" for a while but later on went back to normal operations. On the ither hand tha Lenovo died as I wrote.
      • vince59
        • Nov 2017
        • 46
        • italy
        Any help?
        PS: I made mistake in the thread tilte. How can I modify the title?....Lenovo instead of Lenox​
        • Sephir0th
          • Oct 2020
          • 1289
          Check the Data Pins, the middle two in the row consisting of four, in diode mode. Black probe to data pin, red probe to GND.
          When switch to Ohms mode, range 200 and measure the outer pins. One is supposed to be GND, one is supposed to be the 5V rail. Red probe to the pins, black probe to GND.
          Share the readings here.
          Edit: But seriously, i don't have much hope for your device.
          • vince59
            • Nov 2017
            • 46
            • italy
            data pins: both USB pins give ohm reading 270 and 830 ohm
            power pins: both power pins give OL.
            Yes I have just little hoep...just give a try.
            • Sephir0th
              • Oct 2020
              • 1289
              Read my advise again please. I have left detailed instructions what to do.
              • vince59
                • Nov 2017
                • 46
                • italy
                Hi, "vielen danke" for you help. I did exactly as you requested. I have tow USB sockets and readings with a Fluke multimeter are as follows:
                socket 1: data pins, diode mode, 808 - power pins, ohm meter OL;
                socket 2: data pins, diode mode, 268 - power pins, ohm meter OL.
                I tink I did it correctly.
                • Sephir0th
                  • Oct 2020
                  • 1289
                  Ok. You probably need to open the laptop to get a more clear symptom/sign of failure.
                  Like a (partial) shorted power rail for example.
                  • vince59
                    • Nov 2017
                    • 46
                    • italy
                    I did it I have the mb removed...I am inspecting it....found the problem... hope this is all...TAIMAG IH-189-A ...exploded
                    Last edited by SMDFlea; 07-20-2024, 08:01 AM. Reason: posted image from external site
                    • mon2
                      • Dec 2019
                      • 14634
                      That is an Ethernet transformer and this corner chipping is a common problem when you peel off the sticky foil. Keep hunting as this may not be the fault.
                      x250 broke, doesnt boot, beeps . this chip is all busted inside, what is it : r/thinkpad (reddit.com)
                      • vince59
                        • Nov 2017
                        • 46
                        • italy
                        I can't believe that...I thought it was a joke...
                        • vince59
                          • Nov 2017
                          • 46
                          • italy
                          Good morning all, I am back to the issue. I will replace the MB as it si quite chip. Before buying I need to be sure about MB model. The laptop is a X240 i5. As the laptop is not working I can get additional information about i version of CPU. The market offers several models and I found an i5 4th. I am not sure about "i" generation...how can i solve this doubt?
                          • vince59
                            • Nov 2017
                            • 46
                            • italy
                            silly question...what if I remove the HD fomr the dead laptop and put it on another laptop. Will it work? Does it need to be same brand model or what?
                            • vince59
                              • Nov 2017
                              • 46
                              • italy
                              I tesetd the HD on another laptop HP 820 g3 it works perfectly
                                Lenovo ThinkPad X240 Notebook X Specification for Upgrade or Repair
                                This specification for the Lenovo ThinkPad X240 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X240 boardview and X240 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                09-06-2024, 08:35 AM
                                09-06-2024, 06:14 AM
                              • andrhouseolly
                                Lenovo X240 - motherboard replacement for X250, no image.
                                by andrhouseolly
                                Friends. I beg you to help me in this situation.
                                Lenovo X240 with a video problem. Native Intel drivers are not installed,
                                after installation, a black screen. It works with the standard Microsoft driver.
                                Understanding that there are problems with the video core,
                                I ordered a motherboard from Lenovo X250.
                                The laptop turns on, starts up, there is no image on the internal display.
                                The image is output to the external monitor.
                                I ordered another motherboard from Lenovo X250.
                                07-12-2024, 03:02 PM
                              • coasterghost
                                Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                by coasterghost
                                For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                System Hardware:
                                Processor: AMD Ryzen 7 PRO 5850U
                                Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                09-08-2025, 10:46 PM
                              • rddube
                                Need help interpreting schematic of Lenovo B470 motherboard
                                by rddube
                                OK, so here is my issue.
                                This Lenovo B470 motherboard I am troubleshooting died and I identified it is the discrete Nvidia graphics chip that has lost it's ways!
                                So I removed it and now I am trying to change this motherboard to use UMA graphics, but I am having an issue interpreting the attached diagram. I have a 10K resistor in at the R2013 position and another one at the R2012. R2010 and R2011 are empty.
                                The motherboard starts, the fan spins but no display. It turns off by itself. I restart it and it does start but stays on...
                                08-12-2024, 02:01 PM
