nm-c171 rev:1.0 s145-ast backlight proplem
  • sonerpc
    • Oct 2015
    • 34
    • turkey
    On the s145-ast lenovo laptop with nm-c171 rev:1.0 motherboard, the image appears without illumination. When I look carefully, I can see the lenovo text. I downloaded the bordviewer and the schematic from the badcaps family, but which voltages should I measure? 20 volts come out from both ends of the fuse.
  • Bonzas
    • 472
    • Indonesia
    Measure this pin voltage on JEDP1 :
    1) +LEDVDD ( 19v )
    2) DISPOFF# ( 0v = active low )
    3) INVT_PWM ( 3v )
    4) LCDVDD_CON ( 3v )
    but before doing that. if it's me, i'll try with another lcd
    • sonerpc
      • Oct 2015
      • 34
      • turkey
      1) +LEDVDD ( 19v )
      3) INVT_PWM ( 3v )
      I tried it with another LCD panel. The result did not change. I will check the voltages you mentioned.
      • sonerpc
        • Oct 2015
        • 34
        • turkey
        1) +LEDVDD ( 19v )
        3) INVT_PWM ( 3v )
        INVT_PWM ( 3v ) There is no voltage on this pin. There is no 3v signal. There are other voltages you mentioned.
        • Bonzas
          • 472
          • Indonesia
          If you brave enough, remove R19 and make jumper on invt_pwm side from 3vs. But make sure no short on invt_pwm pin
          • Maestro Electronics
            • Dec 2023
            • 3
            • Kyrgyzstan
            its can be backlight lcddriver
            • mon2
              • Dec 2019
              • 14487
              Does pin 4 (EN) of U7 have a voltage? U7 may be defective.
              • sonerpc
                • Oct 2015
                • 34
                • turkey
                There is no short circuit, but how should I do it? Can you give me some more information, where is r19?
                • Bonzas
                  • 472
                  • Indonesia
                  There's boardview on here
                  https://www.badcaps.net/forum/troubl...52#post1759252
                  • triplefour
                    by triplefour
                    09-13-2023, 10:43 PM
                  • DanPoka
                    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                    by DanPoka
                    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                    02-15-2025, 05:05 AM
                  • Comp_Pro
                    No Backlight Macbook A1990 820-01041
                    by Comp_Pro
                    Hello all,
                    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                    Tests performed:
                    There is no backlight even with a good screen.
                    Backlight IC is receiving the correct support voltages.
                    Fuse F8400 ok
                    Current sense resistor R8400 ok
                    Backlight IC is receiving 3.3V on enable pin.
                    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                    Backlight IC receiving 5V from PP5V_G3S
                    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                    05-06-2024, 10:23 PM
                  • cheebster
                    iPad Pro 12.9 5th Gen Backlight Issue
                    by cheebster
                    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                    Anyone...
                    05-20-2025, 09:17 AM
                  • canadaboy25
                    LG Flatron 24EN33TA No Backlight When Cold
                    by canadaboy25
                    I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                    I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                    03-07-2023, 12:23 AM
