MACBOOK A2251
+ More Options
Posts
  • laptopcenter
    • Mar 2019
    • 90
    • haifa
    MACBOOK A2251
    I have a problem with my Mac A2251 when I download a Mac version, it asks for an update from the Internet, and when I connect it to the Internet, it starts downloading and after a quarter of an hour it restarts and every time it does that until an error message 2100F appeared I checked the temperature of the device intact and there is no high heat, can I help solve the problem.
  • mon2
    • 14627
    You have an internet / wifi connection issue. Consider to use a USB ethernet dongle or fix your wifi connection.
    4 Wix Features You Gotta Know (youtube.com)
    • MikoMiko
      MacBook Pro A2251 - 820-01949-A not charging
      by MikoMiko
      Hello everyone, I have a MacBook Pro 13” 2020 (Four ports) (Model A2251 with the 820-01949-A logicboard). It had some minor liquid damage but I carefully cleaned the logic board with alcohol and let it dry as needed. Now I encounter following situation: The MacBook does start but the Battery is not charging when a cable is plugged in any of the ports (I use the powerbrick and cable that came with the device). It had some charge left, so I could safe some data, but I was limited my the 13% and the speed of airdrop. The liquid-damage is almost only limited to the side of the logic board where...
      03-24-2025, 11:09 AM
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
    • PITERPENY
      Macbook A2251 no boot
      by PITERPENY
      The MacBook does not boot. It is restored via DFU without errors. The MacBook charges and consumes 20V/2A. There is no sound when connecting the charger. The caps lock does not light up, but the touchpad clicks. The fans do not rotate. No signs of life. Please advise.
      01-05-2025, 03:11 PM
    • mferna14
      MacBook Pro A2251 820-01949-A stuck on 5V
      by mferna14
      Hi Dear friend., I am working MacBook Pro A2251 Logic board 820-01949-A. The history was that there was slight liquid on the LHS CD3217 & was not powering on at all. No 20v or any amps. I replaced with known good CD3217s & then got the power but its stuck on 5V .18amp. I did power measurements which are below:
      PPBUS_G3H=12v
      PP3V3_G3H=3.3v
      PP3V3_UPC_X_LDO=3.3v
      PPDCIN_G3H=5v ????
      PP1V8_SLPS2R=1.8v
      Do you think the other RHS CD3217 have to be replaced to as they might have gone defective????​
      11-08-2024, 05:35 PM
    • Arshad alam4659
      macbook a2251 no power
      by Arshad alam4659
      i have a macbook a2251 820-01949-a 5v stuck with 0.274ma
      some measured volt
      PP3V3_G3H_RTC=3.3v
      PP1V8_SLPS2R=1.8v
      PPBUS_G3H=12v
      PP3V3_G3H=3.3v
      P5VP3V3_VREG3=3.3v
      PP5V_S5_LDO=0v
      PP20V_USBC_X_VBUS=0v...
      10-24-2024, 02:29 AM
