MacBook A1707, 820-00928 - No power, 20v, drawing current sporadic between 350ma and 10ma
  • survivalbloke
    • Aug 2021
    • 280
    https://photos.app.goo.gl/Xg2jZmAocXDU6XgUA here is a video. I completed a visual inspection of the logic board and did not see any obvious faults. I have checked for PPBUS_G3H @ C8008/1 and I find it cycles from 13v - 0v and back. For reference, I'm unaware there is a schematic and boardview available for the 820-00928 So I'm using the BV and schematic for 820-00281 as mentioned somewhere here on Badcaps. Where should I go next?
  • mon2
    • 14030
    Remove all power -> measure the resistance to ground of each inductor. Checking for a lower than normal resistance measurement.
    • survivalbloke
      • Aug 2021
      • 280
      Nothing out of the ordinary. A few inductors in gpu and cpu Vcore are 1.9ohm which I believe is normal on these.
      • mon2
        • 14030
        Remove the fuses (F7000 & F7001) on PPBUS_G3H and then power up again. Check if the PPBUS_G3H rail is then stable and with which voltage?
        • survivalbloke
          • Aug 2021
          • 280
          Removed F7001 and F7000 and I have steady 12.6V on pin 1 of both, and steady .6V on pin 2 of both.
          • mon2
            • 14030
            Remove all power. Measure the resistance to ground of pin # 2 of the removed fuses. What is the measurement?
            Next, place one meter probe on pin # 2 of the remove fuses. Other meter probe to any inductor on the board. Checking for a low resistance between the 2 points of measurement. Continue to test other inductors on the board using the same process. If you find a low resistance reading then this means the high side mosfet which functions with the ppbus_g3h rail has shorted on that buck regulator (lower voltage) rail.
            • survivalbloke
              • Aug 2021
              • 280
              Power removed, Pin 2 of both fuses resistance to ground is 38Mohms. Resistance to grond from Fuse pin 2 to inductors was ~32Mohm on all but the largest, near the battery connector, which was 22Mohm. Why does the reading change if I swap the leads' positions? Red lead to fuse pin 2, black lead to battery charging coil, .7Mohm, switch them, 22Mohm.
              • mon2
                • 14030
                https://www.reddit.com/r/macbookrepa...ery/?rdt=61813
