Macbook A2141 820-01700 no image
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    Hello! A little liquid got onto the 8500 connector, which led to a short circuit in the EDP_INT_AUX_N line in the U9850 Click image for larger version
ID:	3297812 . according to the scheme U9850 Click image for larger version
ID:	3297815 is identical to the MacBook A1707 820-00928 Click image for larger version
ID:	3297813 and I took it from this board and replaced it! (maybe they are not interchangeable? Tell me, otherwise the markings on them are different but according to the scheme they are identical)! I checked the display works on A1707. The cable was replaced and installed from A1707. (as I understand, on A2141 you can install a cable from A1707-A1990, but not vice versa). MacBook works with external display!
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    • PITERPENY
      • Jul 2023
      • 455
      • Ukraine
      • mon2
        • Dec 2019
        • 14172
        Check the voltage to ground of LCD_MUX_SEL.
        Check the voltage to ground of LID_OPEN_SMC_IN. Open the lid of the laptop -> measure this voltage.
        • PITERPENY
          • Jul 2023
          • 455
          • Ukraine
          Are these chips interchangeable?
          LCD_MUX_SEL=53,3kohm(diod mode=1.107)
          LID_OPEN_SMC_IN​=47.7kohm( diod mode=0.426)
          • mon2
            • Dec 2019
            • 14172
            The part is pin for pin and appears to be only a standard MUX (multiplexer). I would conclude yes.
            Requested the voltage to ground measurements (not resistance / not diode mode). We are checking if the logic levels (voltage) are present for the requested pins that select A or B side of the mux to the output.
            • PITERPENY
              • Jul 2023
              • 455
              • Ukraine
              I apologize for the misunderstanding!
              LID_OPEN_SMC_IN=1.8 v
              LCD_MUX_SEL​=0v ((board on the table, display not connected) is this voltage present without a connected display?
              • mon2
                • Dec 2019
                • 14172
                Yes, connect the lcd.
                https://www.ifixit.com/Answers/View/...ternal+is+fine!
                • iMuhtaseb
                  • Jan 2017
                  • 122
                  • Palesine
                  chips are interchangeable yes
                  • PITERPENY
                    • Jul 2023
                    • 455
                    • Ukraine
                    thanks for the direct answer!
                    • PITERPENY
                      • Jul 2023
                      • 455
                      • Ukraine
                      Originally posted by mon2
                      Today I bought a new LCD for this MacBook but it won’t turn on either! The screen is always black and there is not even a backlight!
                      • PITERPENY
                        • Jul 2023
                        • 455
                        • Ukraine
                        it was not easy! but I measured the voltage with the display connected.
                        LCD_MUX_SEL=0.004v
                        LCD_MUX_SEL =0.502(diod mode)
                        LCD_MUX_SEL​=4,59 kohm
                        • mon2
                          • Dec 2019
                          • 14172
                          Have you reset NVRAM & SMC?
                          • PITERPENY
                            • Jul 2023
                            • 455
                            • Ukraine
                            Yes, sure !
                            • PITERPENY
                              • Jul 2023
                              • 455
                              • Ukraine
                              no ideas ?
                              • mon2
                                • Dec 2019
                                • 14172
                                Does this logic board work with an external display? Use a type C dongle with a HDMI port for testing.
                                Does the caps key LED toggle?
                                What is the current & voltage draw when the unit is powered by an external adapter? Need to confirm if the logic board is working or not.
                                • PITERPENY
                                  • Jul 2023
                                  • 455
                                  • Ukraine
                                  ​​​​​​in the first post I indicated that the MacBook works with an external monitor)
                                  • PITERPENY
                                    • Jul 2023
                                    • 455
                                    • Ukraine
                                    The MacBook is fully working and charging, there is only no image on the built-in display!
                                    • PITERPENY
                                      • Jul 2023
                                      • 455
                                      • Ukraine
                                      right here
                                      • PITERPENY
                                        • Jul 2023
                                        • 455
                                        • Ukraine
                                        why is everyone ignoring me?
                                        • sofles
                                          Macbook Pro 16" A2141 screen artefacts, kernel panic
                                          by sofles
                                          Hi there.
                                          I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
                                          I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
                                          Now situation looks like this, If...
                                          02-05-2025, 05:05 AM
                                        • leonemax81
                                          Macbook a1707 820-00281 Battery no Power
                                          by leonemax81
                                          Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                                          08-23-2024, 09:24 AM
                                        • Arshad alam4659
                                          MACBOOK PRO A2141 SSD SHORT
                                          by Arshad alam4659
                                          I HAVE A MACBOOK PRO A2141 820-01700 THIS BOARD IS PP2V5_NAND_SSD1 SHORT TO GROUND THEN I CHECK ONE SIDE U8600 IS SHORT THIS SIDE IS ONLY ONE CHIP U8600 OTHER SIDE
                                          PP2V5_NAND_SSD1 IS OK AND U9100 U9200 U9300 U9400 IS ALSO OK Will removing the U8600 fix the board or will I have to install a new one
                                          Link to boardview --> https://www.badcaps.net/forum/troubl...91#post1449091
                                          10-01-2024, 08:26 AM
                                        • sofles
                                          Macbook a1707 2017 model 820-00928 GPU issue
                                          by sofles
                                          Hello there
                                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                          11-21-2024, 05:25 AM
                                        • tommy97
                                          Apple MacBook A1707 No Audio/Sound
                                          by tommy97
                                          I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
                                          I've also replaced U6300, but the problem persists.
                                          Here are the current voltage readings:
                                          • PPV18_S0: 1.8V
                                          • R6402: 1V
                                          • R6405: 1V
                                          • R6403: 1V
                                          • AUD_SPKRAMP_RESET_L: 1.3V
                                          • PPBUS: 12.6V
                                          03-10-2025, 11:22 AM
