KEYBOARD ACER 4741 not working
+ More Options
Posts
  • fardhan_rajab56
    Paklar
    • May 2012
    • 49
    • INDONESIA
    hello !!
    I have a problem On leptop ACER 4741
    I tried to move the keyboard on another device, the keyboard function.
    4741 device does not work at all
    What do you think?
  • tomodachi
    • Apr 2012
    • 607
    • Turkey
    Re: KEYBOARD ACER 4741 not working
    Bad KBC chip I think.
    • fardhan_rajab56
      Paklar
      • May 2012
      • 49
      • INDONESIA
      Here I Found CHIP ENE (KB3930QF) !
      that was Chip KBC what you mean ?
      • fardhan_rajab56
        Paklar
        • May 2012
        • 49
        • INDONESIA
        If the damage occurs right there
        I'll check it out
        thank you for the information
        • tomodachi
          • Apr 2012
          • 607
          • Turkey
          I'll check it out
          Yes, that is the chip I mentioned, replace it.
          • fardhan_rajab56
            Paklar
            • May 2012
            • 49
            • INDONESIA
            Wow That is very good ...
            keyboard finally works again ...
            thank you for helping
            This is remarkable
            • tushar ahamed
              • Mar 2013
              • 6
              • bangladesh
              need bios acer 4741 .. does any one help me out ...
              thanks
              • fardhan_rajab56
                Paklar
                • May 2012
                • 49
                • INDONESIA
                You Must Go Into www.acer.com site you are looking for (DEVICE AND SUPPORT) there are a lot of Bios drivers for Acer Laptops All Types
                • fichamba
                  MSI GL75 Leopard keyboard (almost) not working - HELP
                  by fichamba
                  Hello everybody:
                  Let me put all the laptop's info before describing the problem:
                  BRAND: MSI
                  MODEL No.: MS-17E7
                  SKU: GL75 Leopard 10SEK-261XES-BB71075H16GXXDXX
                  MoBo: MS-17E71 VER. 1.0
                  This laptop arrived to fix the broken left hinge, due to a hit. The hinge was repaired, and when I went to check it out, everything worked well, but I observed certain artifacts (mainly random lines) in the screen.So I decided to remove the screen bezel again, and I saw certain damage to the main LCD harness.
                  This time I also observed that the right...
                  10-09-2024, 04:53 PM
                • SuperAman
                  Keyboard replacement not working issues with Win 10/11 (2) different laptops
                  by SuperAman
                  I have had an issue that I've never come across in all my years of laptop repairs and it has happened twice in the last couple of weeks. The issue occurred on 2 laptops.
                  1. The first laptop a Lenovo Yoga 7 convertible 14 inch 13th gen i7. This laptop came in working, customer wanted to replace the top keyboard assembly for cosmetic reasons so I replaced the keyobard assembly and put their touchpad in it. After booting into windows it would not work, so I assumed I needed to update it or something. Since they didn't give me the Admin account, as it was a company laptop and the...
                  08-31-2024, 07:30 PM
                • Vliegenier04
                  Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
                  by Vliegenier04
                  Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
                  I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
                  Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
                  06-16-2025, 12:03 PM
                • hopkok
                  Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                  by hopkok
                  Hi masters, I need your help.
                  I am working on Lenovo Legion 16ITHg6
                  Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                  INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                  My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                  AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                  Power LED is not working as well, power button working well.
                  UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                  Motherboard...
                  05-04-2025, 09:35 AM
                • ronaldopdias
                  Dell Alienware x17 R1 - Keyboard not working
                  by ronaldopdias
                  Symptoms:
                  No keys work apart from F1, F7, F12 function keys such as keyboard brightness, touchpad enable/disable.
                  Keyboard RGB works okay and might be adjustable.
                  VERY occasionally it may function but most of the time it is dead.
                  The fault is down to the USB data lines not going low when the bus is idle. The keyboard connects over USB, so the issue on the USB data bus causes it to stop functioning.
                  The fix is to fit a 1K resistor to the daughterboard that the keyboard + trackpad connect to. The daughterboard is located beneath the battery. The resistor...
                  05-13-2025, 04:50 AM
