Macbook a1932 820-01521
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    Hello. I need your help . board outside the body. From the owner's story, he tried to replace the battery himself, after which it stopped working with both the old and new batteries. consumption 5v / 0.000a (not stable. sometimes jumps to 0.044 and again 0.000a).
    PPBUS_G3H=12.29v
    PPBUS_HS_CPU=12.28v
    PPDCIN_G3H=5v
    PP5V_G3S=0v
  • mon2
    • Dec 2019
    • 14659
    Check the resistance to ground of PP5V_G3S (with no power to the board).
    • PITERPENY
      • Jul 2023
      • 461
      • Ukraine
      PP5V_G3S=diod mode 0.392
      PP5V_G3S=8 kohm
      PP5V_G3S=0v
      ​PPVBAT_G3H_FUSE=0.156v
      • mon2
        • Dec 2019
        • 14659
        See attached for DIODE values for this logic board.
        • PITERPENY
          • Jul 2023
          • 461
          • Ukraine
          I took the board from a work laptop and it does not match these parameters as in the picture! Here is a picture with real indicators of the working board!
          • PITERPENY
            • Jul 2023
            • 461
            • Ukraine
            and here are the indicators of the board that are under repair
            • bouch
              unlock macbook air A1932 2019
              by bouch
              hi
              i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
              i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
              i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
              have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
              I need help or information?
              Does anyone have the minat2 activator 1.4 software?
              Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
              Thank yo...
              03-12-2025, 10:14 AM
            • nikolayu
              MacBook Air A1932 internet recovery loop
              by nikolayu
              I have A1932 that is going to internet recovery every time.
              i tried nvram and smc reset but it looks that MacBook is not reacting to that.
              i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
              keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
              also won’t open option to boot from usb device.
              and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
              07-22-2025, 02:55 AM
            • TOMÁŠ
              MacBook Air A1932
              by TOMÁŠ
              Hi, I've never worked with a MacBook before, so I need some advice.
              I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
              05-20-2025, 11:19 AM
            • Arshad alam4659
              macbook air a1932 sign out of find my
              by Arshad alam4659
              Today I receive a MacBook Air A1932, its apple ID has been deleted but when I am resetting it is showing a message(sign out of find my ) customer's have no apple id he bought this MacBook from someone else can someone help me remove this message...
              04-09-2025, 12:37 AM
            • astroboypaul
              Macbook A1932 Some Keys Not Working
              by astroboypaul
              Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
              Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left...
              06-10-2024, 05:32 AM
