MACBOOK A1534 820-00244 Logicboard Dead
  • felix27
    • May 2023
    • 12
    • Austria
    I want to fix a 2016 12 Inch Macbook which has a dead Logic Board.
    USB-C and Battery section seems to work, trackpad clicks, but all cpu Voltages, (VCORE, CPUSA) are 0V, CPU stays cold.
    PPBUS_G3H, 3.3V and 5V Rails seem normal. PM_SLP_S3_L is present but CPU_VR_READY is not.
    Thanks for your help!
  • felix27
    • May 2023
    • 12
    • Austria
    ALL_SYS_PWRGD is also present, so i guess, either U7800 or U7100 have some sort of problem. But resistance on the ALL_SYS_PWRGD line is normal, it is not shorted to gnd.
    • mon2
      • 14332
      What is the current draw? Working at 20v?
      Power cycling or steady voltage & current draw?
      • felix27
        • May 2023
        • 12
        • Austria
        I do not have an USB ampmeter, but imput voltage is steady at 20v measured at C3101
        • felix27
          • May 2023
          • 12
          • Austria
          PPVCCIO_S0 is only 0.84V and PM_PCH_PWROK is not present.
          • mon2
            • 14332
            What is the exact voltage to ground of PPBUS_G3H? (measure @ white fuse F7040)
            • felix27
              • May 2023
              • 12
              • Austria
              PPBUS G3H is 8.8V
              U3900 gets warm (not extremly hot). Is that normal?
              Could my EFI-Firmware be the Problem?
              • PITERPENY
                • Jul 2023
                • 455
                • Ukraine
                as they said on one site “probably a bad CPU)”
                • mon2
                  • 14332
                  https://boards.rossmanngroup.com/thr...o-power.60238/
                  • felix27
                    • May 2023
                    • 12
                    • Austria
                    Thing is, I don't even get vcore and all resistances seem normal. My CPU stays completly cold and CPU VRM isn't even turning on. The PCH doesn't create PM_PCH_PWROK but there is SPI activity on the ROM IC, so the PCH isn't completly dead either.
                    • felix27
                      • May 2023
                      • 12
                      • Austria
                      I looked at the schematic again and PM_PCH_PWROK isn'r even generated by the PCH. All Voltages that depend on U7100 are gone, even PPVCCSA. Could just U7100 be dead?
                      • jesi
                        macbook pro a1707 dead
                        by jesi
                        hi all techs
                        require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
                        adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
                        update:
                        when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
                        Yesterday, 04:34 AM
                      • robka
                        MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                        by robka
                        my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                        I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                        The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                        After that the Macbook was dead. It isn't charging anymore.
                        The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                        03-02-2024, 02:58 PM
                      • stefanbs
                        Fit 820-00244-А board in Apple Macbook A1534 2017 820-00687-А
                        by stefanbs
                        The laptop is Apple Macbook A1534 2017 with board 820-00687-А. The USB-C tester shows no voltage, there is 820-00244-А board available. I looked at both schematics, all connector signals seem to be the same. Did someone try to fit 820-00244-А board in A1534 2017?
                        05-11-2025, 01:08 AM
                      • Rav_tangle
                        MacBook Pro 2011 turns on with keyboard light , screen dead
                        by Rav_tangle
                        Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                        I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                        Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                        is this...
                        05-31-2024, 04:09 PM
                      • obelix24
                        Macbook A1534 820-00244 - 5V 0,2A
                        by obelix24
                        Hi All,
                        i got one Macbook a1534 boardnumber 820-00244 that is taking only 5V 0,2A
                        I've tried to replace 3x CD3215B01 chip but it's still behaving same ....
                        On the board there was blown L4804 so i've replaced it.
                        when power is connected 5V 0,2A
                        PPBUS_G3H - 0V
                        PP20V_USBC_XA_VBUS_F - 5V
                        I've tried to remove F7040 as mentioned here
                        https://www.badcaps.net/forum/troubl...1534-820-00244
                        but there is...
                        04-29-2024, 07:48 AM
