Macbook Pro M2 820-02773 5v 0A
  • luckydip
    • Aug 2016
    • 165
    Working on this macbook, showing 5v 0A from charger - dead. Board is clean - no liquid, owner said he left it charging and died. Some voltages:
    After looking at board closely found L8430 damaged/blown open circuit so replaced it. No change, still 5v 0A - I'm thinking over current on L8430 (PP3V8_AON_MPMU_ISNS_VIN) killed U8100?
    Tried connecting to another macbook but not in DFU mode. Forced DFU points have very low volatge so haven't bothered with that.
    Any other ideas?
  • luckydip
    • Aug 2016
    • 165
    Forgot to say - no shorts on major power rails including PP3V8_AON_MPMU_ISNS_VIN, L8430 hasn't blown since replacement. Also noticed another coil L7700 (PP3V8_AON_SPMU_ISNS_VIN) is slightly wonky but reads fine and 3.8v on both sides.
    • mon2
      • Dec 2019
      • 14660
      Remove all power -> meter in resistance mode -> measure the resistance to ground of:
      PP1V8_AON (created by J16 of U8100)
      Measure the voltage to ground of:
      I2C_SMC_PWR_1V8_SCL
      I2C_SMC_PWR_1V8_SDA
      U5200 (ISL9240) is not getting boosted which occurs over the above I2C lines. If 1v8 is missing, then gathering this is the reason for this voltage PPBUS_AON to be not boosted to ~13 volts by the SMC.
      • luckydip
        • Aug 2016
        • 165
        Thanks for the reply.
        PP1V8_AON resistance to ground 455k diode 435mV
        Voltage
        I2C_SMC_PWR_1V8_SCL 574mV
        I2C_SMC_PWR_1V8_SDA​ 578mV
        So does 1v8 come from U8100 or somewhere else?
        • mon2
          • Dec 2019
          • 14660
          Yes, U8100 appears to be the creator of this power rail. Confirm the presence and conditions of L8230 and also R8230. This power rail is not shorted, yet is not working.
          U8100 may be defective. Any visual defects on this part?
          • luckydip
            • Aug 2016
            • 165
            L8230 and R8230 both visually ok and have continuity
            U8100 appears clean and undamaged but I have a suspicion that it may have been fried with a over current pulse when L8430 was blown
            Once again, thanks for taking the time.
            • envym
              MacBook Pro 2018 with Activation Lock
              by envym
              Hi everyone!
              I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
              I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
              06-27-2025, 08:54 AM
            • Flasman90
              Macbook Pro DFU Restore Issues
              by Flasman90
              I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
              - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
              - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
              08-30-2025, 10:27 AM
            • tobeend
              Bypass mdm macbook m2 ventura
              by tobeend
              1. RESET MACOS WITH IPSW
              a. Power off MacBook, press and hold the power button to enter Recovery
              b. Open Disk Utility, remove Macintosh HD
              c. Reboot, connect to the network to Activate Mac.
              d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
              d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
              e. Release the other keys, but keep holding the Power key for another 10 seconds
              f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
              05-26-2023, 07:18 AM
            • SarcasticOP
              General question about MacBook power rails for repair.
              by SarcasticOP
              I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
              • PPBUS_G3H (12.6V-12.8V)
                • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
              • PP3V42_G3H (3.42V)
                • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
              • PPVRTC_G3H (3.3V)
                • This
              12-12-2024, 05:50 PM
            • obelix24
              A2941 Macbook air 15” - 5V 0a
              by obelix24
              I’m working on one macbook air 15” m2 that was water damaged.
              keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
              i’ve put macbook in shelf and order new screen so i can fully repair it.
              Now i got the screen and macbook stays at 5v 0a.
              i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
              i don’t have schematics so i don’t know where to start can someone help me?...
              03-27-2025, 01:19 PM
