A2289 won't power on
  • sauce
    • Sep 2013
    • 148
    • France
    I bought a faulty A2289 for myself.
    The USB-C meter was stuck on 5V.
    After remove the board the U3100 was corroded and also around but quite light.
    So I clean the U3100 and see R2834 in bad condition and its value was not good.
    I replace it and not the USB-C meter shows 20V, the fan is spinning, CPU is hot but nothing else no picture.
    The USB-C meters shows a very low current with all connected. It starts at 20v few mA and then stays at 20v 100mA.
    How mush current the board is supposed to take without nothing connected only the usb-c meter ?
    No voltage on L7210, L7220, L7410, L7420 and L7702.
    Thank you in advance.
  • mon2
    • Dec 2019
    • 14547
    Remove all power. No battery. Measure the resistance (ohms) to ground of each inductor that is missing the correct voltage to ground. Post each measurement.
    • sauce
      • Sep 2013
      • 148
      • France
      Here are the voltages at 0v with resistance to ground.
      PP1V_PRIM 0V 112.9ohm
      PP3V3_S5 0V 66.2Kohm
      PP1V8_S5 0V 1.6Kohm
      No direct short on any inductors.
      These voltages are taken only with USB-C meter plugged.
      If I plug everything back these voltages are present !
      I don't know if it's normal.
      • sauce
        • Sep 2013
        • 148
        • France
        Very strange these 3 voltages (PP1V_PRIM, PP3V3_S5, PP1V8_S5) are present few seconds after I plug the USB-C meter, are stable, but return to 0v after 10 seconds.
        • mon2
          • Dec 2019
          • 14547
          After the 10 seconds, does the logic board power up again and repeat this ON / OFF cycle? If yes, this is power cycling.
          • sauce
            • Sep 2013
            • 148
            • France
            No once these voltages are lost the USB-C meter show at 20v 100mA.
            I was thinking the corrosion was near U2890 too maybe the chip is fried ? Or need to be program again I saw there was bin files for this chip ?
            But how can we program such chip ? And we just need to program it with original bin found on badcaps ?
            • sauce
              • Sep 2013
              • 148
              • France
              I try to re-program U2890 but still the same problem.
              • mon2
                • Dec 2019
                • 14547
                If you have 20V on the Type C meter, then the CD3217 are working and so is the TBT firmware that is held inside of U2890. The issue is after this power delivery contract of 20V is negotiated, something else is failing after 10 seconds. The main bios should be inspected next. Trying to locate the device in the schematics.
                • mon2
                  • Dec 2019
                  • 14547
                  Confirm that the charging port itself is clean and without corrosion. Apply IPA (alcohol) onto the pads or better if tested with a fresh / known good port. We have seen this issue in the past. The charging port is the small and replaceable board with the 2 x Type C connectors. Do rule this out as a suspect.
                  Avoid This Mistake: MacBook Pro A2289 2020 No Power Repair (youtube.com)​
                  • sauce
                    • Sep 2013
                    • 148
                    • France
                    I tried with brand new charging port still the same.
                    Very strange issue.
                    For now the only suspect thing is the quite low voltage of PPVDDCPU_AWAKE 0.54V.
                    Is it normal ?
                    • mon2
                      • Dec 2019
                      • 14547
                      Yes, appears to be lower than normal range. What is the resistance to ground for this rail ?
                      • mon2
                        • Dec 2019
                        • 14547
                        Also, from logiwiki :
                        PPVDDCPU_AWAKE 10-15 Ohm ; resistance to ground on a good device
                        reference:
                        CD3217 and T2 Power on Sequence - LogiWiki​
                        • sauce
                          • Sep 2013
                          • 148
                          • France
                          PPVDDCPU_AWAKE ​10.2 ohm
                          Everything I an checking is OK and we can find diode readings on openboarddata and all readings are fine too.
                          I force DFU and my hackintosh I made this evening because I don't have any macbook can see the board in DFU mode but when I try revive or restore I have 4042 error.
                          I also have a thermal camera but even with good SSD voltages I don't see any heat from SSD.
                          Is a board only connected to usb-c meter is supposed to run ?
                          • mon2
                            • Dec 2019
                            • 14547
                            DFU error 4042:
                            https://boards.rossmanngroup.com/thr...2-error.64310/
                            • sauce
                              • Sep 2013
                              • 148
                              • France
                              So DFU revive or restore :
                              - without charger => error 4042
                              - with charger plugged before USB => error 9
                              • mon2
                                • Dec 2019
                                • 14547
                                Test with a quality usb 3 rated cable. Are you using Sonoma as the host ?
                                • sauce
                                  • Sep 2013
                                  • 148
                                  • France
                                  Yes it is Sonoma.
                                  • sauce
                                    • Sep 2013
                                    • 148
                                    • France
                                    I give up.
                                    Thank you very much for ypur help.
                                    I think i have a dead ssd ou cpu.
                                    • abajor
                                      A2141 minor liquid damage, U3100 TOP port dead. Periodically boots to 20V ~1A on other USBC ports
                                      by abajor
                                      Just wondering if anybody has seen this issue. I'm assuming that all of the CD3217's are semi functional for the chips to request 20V from the PSU.
                                      This unit had some soda spattered up into the side vent. I ultrasonic cleaned the board, now getting this weird sometimes requesting 20V behavior, then it goes back to 5.2V ~ 25mA The U3200 jack cycles.
                                      I'm hoping this is just an issue with some components between the TOP Jack and U3100 and not U3100 itself.
                                      Not seeing anything unusual on thermals just some of the power supply inductors getting warm when it's requesting...
                                      08-25-2025, 01:13 PM
                                    • semaca
                                      a2289 not booting
                                      by semaca
                                      Hello ,
                                      I have this 13' macbookPro board 820-01987 that will not show nothing on the screen. Webcam light is always on and while the battery is connected, no fan spin ( just a half spin in the beginning ) ,cpu get warm .Battery disconnected the fan is spinning normally.
                                      On the usbC meter I have 20V and is going to max 570mA. With battery connected is drawing up to 2,4A.So battery is charging fine.
                                      What I did : I replace U8110 ( there was no 0,95V on PPVCCIO_S0_CPU and now it's ok)
                                      I replace U7710 , here still no voltage on L7702
                                      There is the required...
                                      06-15-2024, 06:07 AM
                                    • chth96
                                      Is it possible to test small ceramic disc capacitor with analogue meter?
                                      by chth96
                                      I read EBOOK of Testing Electronic Component and found that
                                      "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                      Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                      It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                      Is it really possible to test small ceramic disc capacitor with analogue...
                                      03-09-2024, 10:03 PM
                                      Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                      by sam_sam_sam
                                      I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                      I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                      12-31-2023, 06:04 AM
                                    • Zilicon
                                      MacBook pro A2289 with touchbar stuck at 5V, 0.43A
                                      by Zilicon
                                      Greetings everyone.
                                      I've been trying to resolve the above problem, I need insight into the next step to take. This will be my first time handling this kind of machine hence, any replacement part will need to be ordered for since I do not have replacement parts.
                                      readings on the MB:
                                      PPBUS_G3H is present (12.23v)
                                      PP3V3_G3H is present (3.27v)
                                      PP1V8_SLPS2R is present (1.7v)
                                      The C-ports behavior:
                                      The port that communicated with U3200 delivered the above readings although the u3900, u3100, u3200 regions warmed up.
                                      However, the...
                                      09-13-2023, 01:22 AM
