a2289 not booting
  • semaca
    • Feb 2022
    • 21
    • Belgium
    a2289 not booting
    Hello ,
    I have this 13' macbookPro board 820-01987 that will not show nothing on the screen. Webcam light is always on and while the battery is connected, no fan spin ( just a half spin in the beginning ) ,cpu get warm .Battery disconnected the fan is spinning normally.
    On the usbC meter I have 20V and is going to max 570mA. With battery connected is drawing up to 2,4A.So battery is charging fine.
    What I did : I replace U8110 ( there was no 0,95V on PPVCCIO_S0_CPU and now it's ok)
    I replace U7710 , here still no voltage on L7702
    There is the required voltage on all the coils except on the L7410 , L7420 and L7702 .
    The resistance to ground on these coils is : L7410 4,3 ohm
    L7420 4,3 ohm
    L7702 22,3 ohm
    I tried DFU mode by connecting the pin2 to pin 1 on SE032 and it worked but it didn't do nothing. When I start the restore option the macbook its drawing current but after a few minutes it's stops drawing any current . No any errors , just stop .
    All voltage rails are presents except PVCCGT_S0_CPU and PPVCCEDRAM_S0_CPU .
    Any help would be appreciated .
    Semaca
  • mon2
    • 14998
    What is the voltage to ground of PPBUS_G3H @ F7000 (check both sides of this fuse)?
    Remove all power. Meter in DIODE mode. Red meter probe to ground. Black meter probe to point to test.
    Measure the following points of interest:
    SMBUS_3V3_BATT_SCL ; at the battery connector
    SMBUS_3V3_BATT_SDA
    Post each measurements.
    • semaca
      • Feb 2022
      • 21
      • Belgium
      Thank you for answering .
      PPBUS_G3H @ F7000 on both sides is 12,63V
      MBUS_3V3_BATT_SC .952
      SMBUS_3V3_BATT_SDA .979
      • mon2
        • 14998
        These are good measurements.
        What is the voltage to ground of ALL_SYS_PWRGD_R?
        This signal is used to create the PVCCEDRAMS0_EN_FILT_BUF = ENABLE signal for U7710 on pin # 3.
        • semaca
          • Feb 2022
          • 21
          • Belgium
          ALL_SYS_PWRGD_R​ it's 1,8V while the board is on. The board is on my bench ,out of the enclosure and it's staying on like 10s more or less. Normally they stay always on but this one once it's reach 560mA it's shutting off .
          When usb Cmeter shows 0mA then All_SYS_PWRGD_R it's dropping to 0 .
          • semaca
            • Feb 2022
            • 21
            • Belgium
            I measured ALL_SYS_PWRGD_R on pin 2 from R7759 witch is missing . ON pin 1 should be PVCCEDRAMS0_EN_FILT_BUF​ and it was 0 while pin 2 had 1,8V .
            • Aeisens
              Samsung UE50RU7170 not booting /no picture
              by Aeisens
              Dear all,
              My issue is the following:
              Tv suddenly started to make Strange things and went out. After disconnecting power and restarting, it tried to start but failed. After each attempt it got worse and worse. Now only the Stdb light is on and it is not booting.
              I checked the power supply -> Backlight on when disconnected from mainboard, so I guess Power supply is ok.
              Additionally the upper right part of the main-board makes some whistling noise -> probably issue there and therefore issues with booting
              Question 1: Where should I start to...
              06-24-2025, 03:07 PM
            • Daniel Kubica
              Dell Latitude 5590 i5-8350U LA-F411P kernel panic when booting from USB
              by Daniel Kubica
              I got a bare Dell Lattitude 5590 with missing battery, RAM, RTC battery and Storage, I wanted to put some components in it and use it as my home laptop. After adding a FRU 2GB DDR4 2400 SoDIMM RamaxelRAMI've tried booting Linux Mint from USB, I got an error while trying to boot it. I tried reseating the stick, different slot, didn't help.
              I tried to boot Windows 10 installer, as that was the stock system my model came with, got a BSOD as soon as the installer started booting, different code every time. I've tried switching to AHCI mode, I've tried linux in legacy mode, I've tried compatibility...
              06-14-2025, 09:24 AM
            • sauce
              A2289 won't power on
              by sauce
              I bought a faulty A2289 for myself.
              The USB-C meter was stuck on 5V.
              After remove the board the U3100 was corroded and also around but quite light.
              So I clean the U3100 and see R2834 in bad condition and its value was not good.
              I replace it and not the USB-C meter shows 20V, the fan is spinning, CPU is hot but nothing else no picture.
              The USB-C meters shows a very low current with all connected. It starts at 20v few mA and then stays at 20v 100mA.
              How mush current the board is supposed to take without nothing...
              05-19-2024, 12:20 AM
            • Flasman90
              Macbook Pro A2289 MXK62LL/A (661-14770) - No Startup
              by Flasman90
              Hi everyone - first time poster on here looking to embark on my first repair! Thank you in advance for any help!
              My Macbook only turns on when the charger is plugged in and only the trackpad and fans show signs of life. The display, caps lock light and touchbar do not turn on. There was previous liquid damage to the touchbar but after cleaning and drying the laptop was operational for a year without any issues. There doesn't seem to be any sign of liquid damage to the board, at present.
              What I have done so far:
              - All of the routine diagnostic methods including...
              08-29-2025, 08:38 AM
            • sylvain_92
              iMac 2009 A1312 2009 not booting - 3rd led not on
              by sylvain_92
              I am trying to repair my iMac A1312 late 2009 intel i5.
              First of all it was booting but no screen on internal lcd but working with external one,
              I tried:
              - another screen and led power board (booting no screen - same as before)
              - another mxm graphic card (not booting missing 3rd led)
              * screen and mxm gpu tested are 100% working on another A1312 iMac.
              I putted back the original mxm graphic card and what a surprise, now it's not booting anymore even with the stock parts.
              The main...
              12-23-2022, 03:36 PM
