macbook a1707 820-00928
  • mon2
    • Dec 2019
    • 14010
    You have 20v so believe the cd3215 are working.
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      Originally posted by PITERPENY
      Post U7650 basic voltages:
      23,=12.64V
      22,=3.3V
      12,=3.4V
      13,=1.99V
      29,=5V
      21.=3.4V
      SMC_PM_G2_EN comes high? = 3.4 V
      Are you using 87W charger?​ = used 100W
      For A1707 models You must use an exact 87W OEM Apple brick. For some odd reason the board does not like anything less or more. Hope this helps.
      sigpic
      MEOWING IN THE IMPOSSIBLE UNIVERSE!
      • PITERPENY
        • Jul 2023
        • 455
        • Ukraine
        I tried the Apple 87W unit, it didn’t work! but thanks for the tip. I still have 20v and 0.000a stable
        • PITERPENY
          • Jul 2023
          • 455
          • Ukraine
          maybe this board also has problems with the thunderbolt firmware?
          • mon2
            • Dec 2019
            • 14010
            You have 20V so not TBT linked IMO. Do consider a BIOS reflash but backup the original. PS: Do you have a warehouse of boards in your facility? Nice to have if you do
            • PITERPENY
              • Jul 2023
              • 455
              • Ukraine
              #26
              oh yes, I have a whole box of boards of any kind! with my knowledge there are more and more of them! I'll try to upload a bios from a donor! If it doesn't work, I'll ask you)
              • PITERPENY
                • Jul 2023
                • 455
                • Ukraine
                #27
                so I rewrote several options for the OS, including with a clean region, the board consumption is still = 0V, substitution from other boards also did not give anything! I installed a BIOS chip from this board onto another one and it starts it up! Apparently we need to look for the reason elsewhere (
                • mon2
                  • Dec 2019
                  • 14010
                  Review and share the details from post # 19.
                  • mon2
                    • Dec 2019
                    • 14010
                    What is the voltage to ground of the following points? Given that your PPBUS_G3H is boosted, these lines should be ok but do confirm it. Along with the current PPBUS_G3H voltage to ground.
                    SMBUS_SMC_5_G3_SCL
                    SMBUS_SMC_5_G3_SDA
                    After you attempt to power up, what is the current draw ? Stuck @ 0A ? What is PPBUS_G3H? Stable voltage till you unplug the adapter?
                    • mon2
                      • Dec 2019
                      • 14010
                      Is the other unit that is working with a battery? Test this one with a battery.
                      • PITERPENY
                        • Jul 2023
                        • 455
                        • Ukraine
                        #31
                        I fiddled with it for 2 weeks, replaced the PCH (U1100) and the MacBook came to life. therefore, if A1707 consumes 0.000A, I think 99% of PCH(U1100) should be replaced.
                        • mon2
                          • Dec 2019
                          • 14010
                          Very nice! Personally would have tossed it. Share the details of the donor PCH. Anything special or just replaced from another A1707 donor board?
                          • PITERPENY
                            • Jul 2023
                            • 455
                            • Ukraine
                            #33
                            I took it from the same donor board). but since it’s green I think it’s a product from Intel)
                            • mon2
                              • Dec 2019
                              • 14010
                              Awesome! Thanks for the updates and pix. For this series, I believe they are all from Intel. Later models have the Apple silicon.
                              • leonemax81
                                Macbook a1707 820-00281 Battery no Power
                                by leonemax81
                                Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                                08-23-2024, 09:24 AM
                              • sofles
                                Macbook a1707 2017 model 820-00928 GPU issue
                                by sofles
                                Hello there
                                I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                11-21-2024, 05:25 AM
                              • tommy97
                                Apple MacBook A1707 No Audio/Sound
                                by tommy97
                                I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
                                I've also replaced U6300, but the problem persists.
                                Here are the current voltage readings:
                                • PPV18_S0: 1.8V
                                • R6402: 1V
                                • R6405: 1V
                                • R6403: 1V
                                • AUD_SPKRAMP_RESET_L: 1.3V
                                • PPBUS: 12.6V
                                03-10-2025, 11:22 AM
                              • Cemal Odabasioglu
                                MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                by Cemal Odabasioglu
                                I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                Observations...
                                01-14-2025, 03:54 PM
                              • Instafixx
                                Macbook A1707 820-00928 Panic Log
                                by Instafixx
                                Namaste!
                                We have a Macbook A1707 which came in for repair. Someone had already tried to work on it and there were traces oh heat and burns on the board.
                                The charger was Stuck at 5v and the there was some caps shorted around U3100.
                                Turns out there was corrosion under U3100. Same was Reflowed and the Macbook turned on. Works fine but having 1 issue whenever the Macbook is idle and goes into sleep mode. It will WAKE for 1 Second and then do a restart.
                                It will Display a Black Screen with error message saying Macbook Restarted because of a problem....
                                01-19-2023, 04:15 AM
