macbook a1707 820-00928
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    there is no reaction, it hangs at 20 V/0A. There was a little corrosion in the u7650 area. Replacing the u7000 did not help. Tell me, what else could it be? PPBUS_G3H=12.9V
    Flashing the bios with a clean region also did not work!
  • mon2
    • Dec 2019
    • 14019
    From Rossmann forums:
    Post U7650 basic voltages: 23, 22, 12, 13, 29, 21.
    SMC_PM_G2_EN comes high?
    Are you using 87W charger?​
    • PITERPENY
      • Jul 2023
      • 455
      • Ukraine
      23,=12.64V
      22,=3.3V
      12,=3.4V
      13,=1.99V
      29,=5V
      21.=3.4V
      SMC_PM_G2_EN comes high? = 3.4 V
      Are you using 87W charger?​ = used 100W
      • mon2
        • Dec 2019
        • 14019
        Try..
        "SMC bypass mode"
        Put SMC_ONOFF_L to ground, connect charger, maintain contact 5-10s; board should start when you release SMC_ONOFF_L.
        Remember to work with board alone, nothing connected apart of charger (no battery).​
        • PITERPENY
          • Jul 2023
          • 455
          • Ukraine
          when connected to all 4 ports, the same behavior is 20V / 0A, the consumption of 0A is fixed, not the slightest consumption from the moment of connection.
          • PITERPENY
            • Jul 2023
            • 455
            • Ukraine
            The power tester reboots and still no changes, I tried several times(
            • mon2
              • Dec 2019
              • 14019
              What is the voltage to ground of:
              PP3V3_S5
              PP5V_S4
              • PITERPENY
                • Jul 2023
                • 455
                • Ukraine
                PP3V3_S5=3.3v
                PP5V_S4= 0v
                • mon2
                  • Dec 2019
                  • 14019
                  Remove all power -> meter in resistance mode -> measure the resistance to ground of PP5V_S4.
                  Also confirm, the voltage to ground of the EN1 signal @ P5VS4_EN_RCD. Carefully measure this at the IC.
                  What is the voltage to ground of ALL_SYS_PWRGD ?
                  Click image for larger version  Name:	A1707_power_sequence.png Views:	0 Size:	73.7 KB ID:	3266431
                  • PITERPENY
                    • Jul 2023
                    • 455
                    • Ukraine
                    PP5V_S4= 8,23 kOhm (0.390 diod mode)
                    P5VS4_EN_RCD =0V (46 kOhm)(0.457 diod mode)
                    ALL_SYS_PWRGD​=0V(8.5 kOhm)(0.416 diod mode)
                    • mon2
                      • Dec 2019
                      • 14019
                      With no power to the board, meter in resistance mode, measure the resistance to ground of each inductor (usually grey in color). Checking for shorts on the power rail.
                      • PITERPENY
                        • Jul 2023
                        • 455
                        • Ukraine
                        diod mode/resistance
                        L7030=0.413/43.6kohm
                        L7960=0.33/71.5ohm
                        L8000=0.18/52.9ohm
                        L8020=0.388/8.14kohm
                        L7900=0.215/0.695kohm
                        L7600=0.393/8.32kohm
                        L7660=0.252/2.030kohm
                        L8410=0.778/35.5kohm
                        LB700=0.230/1.697kohm
                        LA300=0.018/54.2ohm
                        LA350=0.013/40.3ohm
                        LA650=0.000/2.7ohm
                        LA640=0.000/2.7ohm
                        L7330=0.007/23.2ohm
                        L7231=0.000/4.2ohm
                        L7221=0.000/4.2ohm
                        L7211=0.000/4.2ohm
                        L7420=0.001/6.7ohm
                        L7410=0.001/6.7ohm
                        I don’t find a short circuit, maybe the problem is in the SD3215?
                        • mon2
                          • Dec 2019
                          • 14019
                          You have 20V so that implies that each CD3215 is operational. You can test by testing each USB Type C connector and also by rotating the USB C connector head by 180 degrees to confirm the operation of each side of the USB blade.
                          Check the voltage to ground of each pin of the main SPI flash ROM.
                          • PITERPENY
                            • Jul 2023
                            • 455
                            • Ukraine
                            U6100
                            1=1V
                            2=0.022V
                            3=0.027V
                            4=0
                            5=0
                            6=0.022V
                            7=0.020V(hesitate)
                            8=0.
                            all 8 sides of USB-C have the same readings
                            • PITERPENY
                              • Jul 2023
                              • 455
                              • Ukraine
                              PP3V3_SUS=0V
                              • mon2
                                • Dec 2019
                                • 14019
                                Check the resistance to ground of this missing power rail. No power during this resistance testing.
                                • PITERPENY
                                  • Jul 2023
                                  • 455
                                  • Ukraine
                                  PP3V3_SUS=0V .DIOD=0.320 .RESISTANS=2.8 kOhm
                                  • PITERPENY
                                    • Jul 2023
                                    • 455
                                    • Ukraine
                                    where is PP3V3_SUS formed?
                                    • mon2
                                      • Dec 2019
                                      • 14019
                                      See attached (U8200). Carefully review the voltage to ground of this critical load switch.
                                      PP3V3_S5 must enter this load switch
                                      EN signal of PM_SLP_SUS_L = '1' = ~3v3 then output will be the PP3V3_SUS to further power other devices.
                                      • PITERPENY
                                        • Jul 2023
                                        • 455
                                        • Ukraine
                                        I removed f7000 and f7001 and my consumption is 20V but 0.000A is stable, I think the problem is in the power circuit and this is the CD3215. What do you think?
                                        • leonemax81
                                          Macbook a1707 820-00281 Battery no Power
                                          by leonemax81
                                          Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                                          08-23-2024, 09:24 AM
                                        • sofles
                                          Macbook a1707 2017 model 820-00928 GPU issue
                                          by sofles
                                          Hello there
                                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                          11-21-2024, 05:25 AM
                                        • tommy97
                                          Apple MacBook A1707 No Audio/Sound
                                          by tommy97
                                          I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
                                          I've also replaced U6300, but the problem persists.
                                          Here are the current voltage readings:
                                          • PPV18_S0: 1.8V
                                          • R6402: 1V
                                          • R6405: 1V
                                          • R6403: 1V
                                          • AUD_SPKRAMP_RESET_L: 1.3V
                                          • PPBUS: 12.6V
                                          03-10-2025, 11:22 AM
                                        • Cemal Odabasioglu
                                          MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                          by Cemal Odabasioglu
                                          I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                          Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                          Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                          Observations...
                                          01-14-2025, 03:54 PM
                                        • Instafixx
                                          Macbook A1707 820-00928 Panic Log
                                          by Instafixx
                                          Namaste!
                                          We have a Macbook A1707 which came in for repair. Someone had already tried to work on it and there were traces oh heat and burns on the board.
                                          The charger was Stuck at 5v and the there was some caps shorted around U3100.
                                          Turns out there was corrosion under U3100. Same was Reflowed and the Macbook turned on. Works fine but having 1 issue whenever the Macbook is idle and goes into sleep mode. It will WAKE for 1 Second and then do a restart.
                                          It will Display a Black Screen with error message saying Macbook Restarted because of a problem....
                                          01-19-2023, 04:15 AM
