macbook a1707 820-00928
  • PITERPENY
    • Jul 2023
    • 462
    • Ukraine
    there is no reaction, it hangs at 20 V/0A. There was a little corrosion in the u7650 area. Replacing the u7000 did not help. Tell me, what else could it be? PPBUS_G3H=12.9V
    Flashing the bios with a clean region also did not work!
  • mon2
    • Dec 2019
    • 14713
    From Rossmann forums:
    Post U7650 basic voltages: 23, 22, 12, 13, 29, 21.
    SMC_PM_G2_EN comes high?
    Are you using 87W charger?​
    • PITERPENY
      • Jul 2023
      • 462
      • Ukraine
      23,=12.64V
      22,=3.3V
      12,=3.4V
      13,=1.99V
      29,=5V
      21.=3.4V
      SMC_PM_G2_EN comes high? = 3.4 V
      Are you using 87W charger?​ = used 100W
      • mon2
        • Dec 2019
        • 14713
        Try..
        "SMC bypass mode"
        Put SMC_ONOFF_L to ground, connect charger, maintain contact 5-10s; board should start when you release SMC_ONOFF_L.
        Remember to work with board alone, nothing connected apart of charger (no battery).​
        • PITERPENY
          • Jul 2023
          • 462
          • Ukraine
          when connected to all 4 ports, the same behavior is 20V / 0A, the consumption of 0A is fixed, not the slightest consumption from the moment of connection.
          • PITERPENY
            • Jul 2023
            • 462
            • Ukraine
            The power tester reboots and still no changes, I tried several times(
            • mon2
              • Dec 2019
              • 14713
              What is the voltage to ground of:
              PP3V3_S5
              PP5V_S4
              • PITERPENY
                • Jul 2023
                • 462
                • Ukraine
                PP3V3_S5=3.3v
                PP5V_S4= 0v
                • mon2
                  • Dec 2019
                  • 14713
                  Remove all power -> meter in resistance mode -> measure the resistance to ground of PP5V_S4.
                  Also confirm, the voltage to ground of the EN1 signal @ P5VS4_EN_RCD. Carefully measure this at the IC.
                  What is the voltage to ground of ALL_SYS_PWRGD ?
                  Click image for larger version  Name:	A1707_power_sequence.png Views:	0 Size:	73.7 KB ID:	3266431
                  • PITERPENY
                    • Jul 2023
                    • 462
                    • Ukraine
                    PP5V_S4= 8,23 kOhm (0.390 diod mode)
                    P5VS4_EN_RCD =0V (46 kOhm)(0.457 diod mode)
                    ALL_SYS_PWRGD​=0V(8.5 kOhm)(0.416 diod mode)
                    • mon2
                      • Dec 2019
                      • 14713
                      With no power to the board, meter in resistance mode, measure the resistance to ground of each inductor (usually grey in color). Checking for shorts on the power rail.
                      • PITERPENY
                        • Jul 2023
                        • 462
                        • Ukraine
                        diod mode/resistance
                        L7030=0.413/43.6kohm
                        L7960=0.33/71.5ohm
                        L8000=0.18/52.9ohm
                        L8020=0.388/8.14kohm
                        L7900=0.215/0.695kohm
                        L7600=0.393/8.32kohm
                        L7660=0.252/2.030kohm
                        L8410=0.778/35.5kohm
                        LB700=0.230/1.697kohm
                        LA300=0.018/54.2ohm
                        LA350=0.013/40.3ohm
                        LA650=0.000/2.7ohm
                        LA640=0.000/2.7ohm
                        L7330=0.007/23.2ohm
                        L7231=0.000/4.2ohm
                        L7221=0.000/4.2ohm
                        L7211=0.000/4.2ohm
                        L7420=0.001/6.7ohm
                        L7410=0.001/6.7ohm
                        I don’t find a short circuit, maybe the problem is in the SD3215?
                        • mon2
                          • Dec 2019
                          • 14713
                          You have 20V so that implies that each CD3215 is operational. You can test by testing each USB Type C connector and also by rotating the USB C connector head by 180 degrees to confirm the operation of each side of the USB blade.
                          Check the voltage to ground of each pin of the main SPI flash ROM.
                          • PITERPENY
                            • Jul 2023
                            • 462
                            • Ukraine
                            U6100
                            1=1V
                            2=0.022V
                            3=0.027V
                            4=0
                            5=0
                            6=0.022V
                            7=0.020V(hesitate)
                            8=0.
                            all 8 sides of USB-C have the same readings
                            • PITERPENY
                              • Jul 2023
                              • 462
                              • Ukraine
                              PP3V3_SUS=0V
                              • mon2
                                • Dec 2019
                                • 14713
                                Check the resistance to ground of this missing power rail. No power during this resistance testing.
                                • PITERPENY
                                  • Jul 2023
                                  • 462
                                  • Ukraine
                                  PP3V3_SUS=0V .DIOD=0.320 .RESISTANS=2.8 kOhm
                                  • PITERPENY
                                    • Jul 2023
                                    • 462
                                    • Ukraine
                                    where is PP3V3_SUS formed?
                                    • mon2
                                      • Dec 2019
                                      • 14713
                                      See attached (U8200). Carefully review the voltage to ground of this critical load switch.
                                      PP3V3_S5 must enter this load switch
                                      EN signal of PM_SLP_SUS_L = '1' = ~3v3 then output will be the PP3V3_SUS to further power other devices.
                                      • PITERPENY
                                        • Jul 2023
                                        • 462
                                        • Ukraine
                                        I removed f7000 and f7001 and my consumption is 20V but 0.000A is stable, I think the problem is in the power circuit and this is the CD3215. What do you think?
                                        • CG_Dionysos
                                          MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
                                          by CG_Dionysos
                                          I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
                                          • Model: A1707
                                          • 15-inch, Mid 2017
                                          • 3.1 GHz Core i7
                                          • 16 GB RAM
                                          • Radeon Pro 560
                                          • 1 TB SSD
                                          • Board number: 820-00928-A
                                          I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
                                          Thanks in advance!
                                          Greetings from Germany...
                                          09-16-2025, 06:43 AM
                                        • leonemax81
                                          Macbook a1707 820-00281 Battery no Power
                                          by leonemax81
                                          Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                                          08-23-2024, 09:24 AM
                                        • sofles
                                          Macbook a1707 2017 model 820-00928 GPU issue
                                          by sofles
                                          Hello there
                                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                          11-21-2024, 05:25 AM
                                        • jesi
                                          MacBook Pro 820-00281-A A1707 macbook
                                          by jesi
                                          hi all techs
                                          require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
                                          adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
                                          update:
                                          when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
                                          08-23-2025, 02:35 PM
                                        • tommy97
                                          Apple MacBook A1707 No Audio/Sound
                                          by tommy97
                                          I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
                                          I've also replaced U6300, but the problem persists.
                                          Here are the current voltage readings:
                                          • PPV18_S0: 1.8V
                                          • R6402: 1V
                                          • R6405: 1V
                                          • R6403: 1V
                                          • AUD_SPKRAMP_RESET_L: 1.3V
                                          • PPBUS: 12.6V
                                          03-10-2025, 11:22 AM
