820-02382 not seeing battery
  • Serbentas
    • Sep 2016
    • 22
    820-02382 (MacBook A2485 16" M1) not detecting battery. Battery sign has cross. However it works from battery but not charging and reporting incorrect data like charge remaining.
    Any one any ideas please? Also fans are high/full speed
  • mon2
    • Dec 2019
    • 14171
    Measure with care the voltage to ground on each pin on the battery connector. Post each measurement.
    • Serbentas
      • Sep 2016
      • 22
      J5151:
      pin 4 (SMBUS_BATT_SDA) - 1.79V
      pin 3 (SMBUS_BATT_SCL) - 1.69V
      pin 1 (SYS_DETECT_L) - 0V
      Battery gets 12V on + -
      • mon2
        • Dec 2019
        • 14171
        The SMBUS interface on the battery connector do operate @ 1v8 swing so the measured voltages are correct.
        Can you share a screen pic of the battery details for your unit? Do you see the serial #, # of charge cycles, etc. correctly? If not, there is some fault here.
        The communication is from a low voltage SMBUS that travels through a voltage level shifter to be compatible with the 1v8 SMBUS swing that is onboard the BMS board that is implanted inside of every battery pack. Perhaps the 1v2 side of the level shifter is not working but confirm your battery screen details.
        Have you tested with another known good battery? Perhaps consider to source from Amazon and return it if it is not required.
        Confirm the voltage to ground of the SYS_DETECT signal as per attached.
        Click image for larger version  Name:	battery_check.png Views:	0 Size:	247.8 KB ID:	3264311
        • Serbentas
          • Sep 2016
          • 22
          SYS_DETECT 3.8V
          Will try to get another battery to test
          • mon2
            • Dec 2019
            • 14171
            Also run a diag on the board to understand the reason for the high fan spin which should a failure status of a sensor or the lack of that sensor’s ability to report back. If the sensor access times out then the fan will also enter turbo mode.
            • Serbentas
              • Sep 2016
              • 22
              Tried 3 batteries, one of them new, all shows that. They work on other Macs and display all info correctly. So Mac fails to read.
              Is U5200 faulty?
              • mon2
                • Dec 2019
                • 14171
                Is U5200 faulty?
                No, because your logic board is booting fine which means that this buck / boost regulator is correctly creating the PPBUS_AON_REG rail. The battery communication is failing which is over the SMBUS interface.
                Review the level shifters that are used in this circuit @ UD102. Carefully measure the voltage to ground of:
                I2C_SMC_PWR_SCL
                I2C_SMC_PWR_SDA
                You have at least the battery not being properly detected but the same cluster of SMBUS slave devices are most likely raising the temp sensor fault resulting in the turbo high fan speed.
                • Serbentas
                  • Sep 2016
                  • 22
                  All looks good.
                  Voltage on both 1.22
                  • Serbentas
                    • Sep 2016
                    • 22
                    Is this the end of the road?
                    • mon2
                      • Dec 2019
                      • 14171
                      Same model?
                      What did the HW diags report?
                      Use Apple Diagnostics to test your Mac - Apple Support (CA)
                      • Serbentas
                        • Sep 2016
                        • 22
                        Diagnostics report only 'might be a problem with fans'
                        • Serbentas
                          • Sep 2016
                          • 22
                          Yes, same models
                          • mon2
                            • Dec 2019
                            • 14171
                            Run coconut battery to see if it reports anything different:
                            coconutBattery 3.9 - by coconut-flavour.com
                            What is the voltage to ground of each of the following?
                            I2C_KBD_SCL
                            I2C_KBD_SDA
                            I2C_TPAD_CONN_SCL
                            I2C_TPAD_CONN_SDA
                            • Serbentas
                              • Sep 2016
                              • 22
                              I have battery tool for macs and it read battery as normal 56% charge, cycle count etc
                              I2C_KBD_SCL/SDA - both 1.8 V
                              And there are no such lines on this board as:
                              I2C_TPAD_CONN_SCL
                              I2C_TPAD_CONN_SDA
                              • Serbentas
                                • Sep 2016
                                • 22
                                Oops.Sorry. Looking at the wrong schematic
                                I2C_TPAD_CONN_SCL
                                I2C_TPAD_CONN_SDA
                                Both 1.85V
                                • mon2
                                  • Dec 2019
                                  • 14171
                                  Try a DFU:
                                  https://maclovin.org/blog-native/202...0documentation.
                                  • Serbentas
                                    • Sep 2016
                                    • 22
                                    Done that already
                                    • mon2
                                      • Dec 2019
                                      • 14171
                                      Did that work for you without issues? What are the test results from the coconut battery tool?
                                      • mon2
                                        • Dec 2019
                                        • 14171
                                        If you take your other known good batteries and run your battery tool, are the results consistent with the strength or charge of the battery? The number of charge cycles are correct? The same non-working battery on this board is detected properly on another identical logic board?
                                        Be sure to confirm your battery contacts on the non-working board.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • mkdj
                                          ASUS X571 no power : battery issue?
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                          Tests already made:
                                          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                          - I have removed...
                                          07-14-2025, 09:16 AM
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • ferah831208
                                          Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                          by ferah831208
                                          Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                          03-18-2025, 01:18 AM
