820-00165 no backlight
  • vinzmt
    • Aug 2023
    • 9
    • italia
    hi to all
    i have this logic board with no back light, image is present.
    unknow istory.
    on q7707 pin 5 EDP_BKLT_EN found 3.3 v, pin 1 gnd damage, pin 2 BKLT_PLT_RST_L only 0.08v (but is 3.3 on r2088 pin 2)
    remove q7707 and find this
    any suggestions?
    thanks
  • mon2
    • Dec 2019
    • 13834
    Post voltages for Q7706/07.
    • vinzmt
      • Aug 2023
      • 9
      • italia
      q7706:
      1:0v
      2:0v
      3:8.3v
      4:8.57v
      5:0v
      6:0v
      q7707 without cip
      2:0.004v
      3:8.2v
      4:0v
      5:3.13v
      6:0v
      • mon2
        • Dec 2019
        • 13834
        Remove all power. Meter in diode mode. Short your meter probes and you should hear a tone beep.
        Connect one meter probe (either color) to R2088, pin # 2 and other meter probe to BKLT_PLT_RST_L on the removed mosfet PCB pad. You should hear a tone beep. If you do not, then the PCB trace is broken.
        Repeat with R2088, pin # 1 - same tone beep should be heard.
        • vinzmt
          • Aug 2023
          • 9
          • italia
          trace is broken. What do you advise?
          • mon2
            • Dec 2019
            • 13834
            Locate a thin insulated wire and solder it point to point. Share the pic of the wire and joints if in doubt.
            • vinzmt
              • Aug 2023
              • 9
              • italia
              Ok, tomorrow i try, thanks 🙏🏻
              • vinzmt
                • Aug 2023
                • 9
                • italia
                I found this wire, does it seem too big?
                • kevingill
                  • Jun 2013
                  • 152
                  • England
                  Don't think the picture made it on to the website
                  • vinzmt
                    • Aug 2023
                    • 9
                    • italia
                    • reformatt
                      • Feb 2020
                      • 1398
                      If you were fixing a car or something, that might be appropriate. But way too big for this application.
                      From the boardview, the connection to Q7707/2 is from a via underneath that area. I'm guessing its to the test pad, which has been eaten away. Since there are no other connections on that side of the board, you'll need to run a jumper that wraps around the board from one side to the other. You will need 0.1mm enameled wire plus some way to tack it down. I use dabs of conformal coating (which you cure with a UV lamp).
                      • vinzmt
                        • Aug 2023
                        • 9
                        • italia
                        I don't have this material at the moment. I'll get it and try it, thanks
                        • triplefour
                          by triplefour
                          09-13-2023, 10:43 PM
                        • DanPoka
                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                          by DanPoka
                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                          02-15-2025, 05:05 AM
                        • Comp_Pro
                          No Backlight Macbook A1990 820-01041
                          by Comp_Pro
                          Hello all,
                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                          Tests performed:
                          There is no backlight even with a good screen.
                          Backlight IC is receiving the correct support voltages.
                          Fuse F8400 ok
                          Current sense resistor R8400 ok
                          Backlight IC is receiving 3.3V on enable pin.
                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                          Backlight IC receiving 5V from PP5V_G3S
                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                          05-06-2024, 10:23 PM
                        • cheebster
                          iPad Pro 12.9 5th Gen Backlight Issue
                          by cheebster
                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                          Anyone...
                          05-20-2025, 09:17 AM
                        • canadaboy25
                          LG Flatron 24EN33TA No Backlight When Cold
                          by canadaboy25
                          I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                          I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                          03-07-2023, 12:23 AM
