DM4 overheating and shutdown.
  • nazrul145
    • Jan 2014
    • 337
    • BD
    Hi i have a overheating problem with HP DM4 core i5. after run sometime it get very heat and shutdown. i use thermal past and same problem. and i change a processor but result is same
    . pls anyone help how to solve this overheat problem. Thanks advance.
  • dj_ricoh
    • 2073
    Re: DM4 overheating and shutdown.
    maybe the heatsink does not touch proper .
    a reflow will not hurt.
    update the bios O.o maybe?
    • nazrul145
      • Jan 2014
      • 337
      • BD
      bios update??? what relation of overheating with bios update??? i m not clear pls.
      • dj_ricoh
        • 2073
        :| cpu not compatible. data corrupt ?
        don`t know it does not hurt, you know?
        • nazrul145
          • Jan 2014
          • 337
          • BD
          may be. i try it tomorrow.
          • trebo
            • 514
            • Wales, UK
            maybe coolant gas has leaked from heatsink pipe, or lint carpet between fins and fan
            • jtamad44
              • Apr 2013
              • 145
              • israel
              if the fan kick up right away, need to reflow the cpu socket to the max. (melt the balls)
              • alibisma
                • Oct 2014
                • 37
                • Saudia
                hi i got the same problem som time and they r working good only resold the vga chip with the past
                • degutji
                  • Dec 2012
                  • 173
                  • Indonesia
                  I've same problem last week, solved by replace an ATI GPU
                  • Ramee
                    • Jul 2014
                    • 218
                    • Israel
                    You can monitor the temperature using SPEECY, just google it or try to install gpu driver. If you manage to install the driver meaning the gpu chip is ok, but if the laptop shut down meaning the gpu is bad and need to be replace with a new one.
                    • akwky
                      by akwky
                      Hi!
                      04-14-2025, 01:56 PM
                    • 0xx
                      2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                      by 0xx
                      Hi folks,
                      My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                      What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                      I assumed that Windows Update was interrupted due to closing...
                      09-14-2025, 03:46 PM
                    • TheUser
                      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                      by TheUser
                      Hello to everyone ,
                      This is my first post here, and i would like to share with you a small story in case you can help me.
                      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                      02-10-2024, 02:07 PM
                    • lordgeny
                      z490-f gaming bricked after bios update
                      by lordgeny
                      I had to assemble a PC with this Z490-F Gaming motherboard and an i7-1700K CPU. Upon the first boot, the CPU LED was red and flashing. I realized that I needed to update the BIOS. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site, and update ME firmware to Version 14.1.53.1649V1.1 to ensure optimized system settings." I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. My attempts to reflash it were unsuccessful. Searching online,...
                      11-02-2023, 09:03 AM
                    • iMuhtaseb
                      A1706 2017 critical update
                      by iMuhtaseb
                      this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
                      we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
                      One weird symptom is it takes too long to power on and show the Apple logo for some reason..
                      I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
                      08-13-2024, 08:41 AM
