Hi, I was thinking of buying one of these to help with my hobby of (sometimes) repairing laptops. I'm not much good with schematics or tracing voltages so I thought one of these things might help pinpoint the problem area for me. Do any of you guys use these? Some are cheap enough on ebay but there are different types being sold and the range in price is quite big. Are they any good? Any recommendations?
Diagnosis/Anaysis cards any good?
Re: Diagnosis/Anaysis cards any good?
They are basically useless in my opinion. I had one and it displayed a code so I tried it on a working laptop and it displayed the same code. I contacted the manufacturers/sellers and they said yes that is correct. I then tried it on about 5-10 different laptops over a year and it was basically the same or gave a clock error code which when read in the instructions basically told you nothing other than check every clock signal and voltage.Maybe it was just the one I bought but I think they are useless compared to a good Oscope and a schematic. -
i also buy about 2 or 3 type all useless. no signal for southbridge, no signal for shorted component what u the device can detect is no ram and no cpu just that.it very easy to trace without the device . forget about itComment
I've tried using one as well. The results were meaningless. Heck, even PCI post cards for desktops are hardly useful. Don't waste your time. Schematic + multimeter method runs circles around these useless post cards.Comment
I wonder if manufacturers still stick to the port 80 standard (if they ever did).
The only useful thing in that direction I ever had was an Epox Socket A mobo that had the thing integrated, with a small 7-segment display. 8RDA3I+ I think it was.
It was helpful a few times.
MSI had something similar where the combination of 4 LEDS on a bracket would light up with the boot sequence.
The Epox was way better IMO. I put in a cheap port80 card for comparison - useless. Garbage.
Too bad they went down, they made good boards.
(one could argue that that port 80 thing was overkill for a consumer board - it probably was. Still neat, though. Like the compass in some Nissans)."Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. MenckenComment
by irepair559PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...01-05-2023, 12:32 AM
by coasterghostFor Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
System Hardware:
Processor: AMD Ryzen 7 PRO 5850U
Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...09-08-2025, 10:46 PM -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by the_remHello guys,
I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow... - Loading...
