Blown Inductor on WD My Passport
  • silver60618
    • May 2021
    • 36
    Hi Guys, my WD My Passport drive powers on, then powers off. Ive taken out the motherboard and identified a blown Inductor. Im trying to recover my data only
    Reading between leads show nothing. If I removed this Inductor, what would be a suitable replacement? am I correct that its a ferrite Inductor is to just filter noise?
    Ive seen people just bridge them, any harm in replacing it with a differnt value Inductor?
    Lastly am I correct in thinking there is no polarity on the smd component?
    Thanks!
  • mon2
    • Dec 2019
    • 14691
    Hi.
    1) correct that there is no polarity to this inductor / ferrite bead. It is essentially a coil of wire on a bobbin.
    2) the purpose of this component is not 100% clear to me. It could be to filter out EMI noise or may be a part of a switching buck regulator which will demand for a replacement of this part. If it is only for EMI noise reduction then this part can be bridged to get the board to be operational.
    3) Suggest, unless known otherwise with confidence, to seek out a replacement controller board (Aliexpress) and remove the same part off the donor board to place onto this board. If you know for sure that the bridging has worked for others, then short away. Measure the size of the part if you really want to replace with alternate ferrite beads from Digikey / Mouser / Arrow, etc.
    4) Share more pics of this board which may allow someone to locate this mytery component.
    • silver60618
      • May 2021
      • 36
      Thanks Mon! Searching for repacement was my next step, if I couldnt salvage something from the bone pile.
      This is another board that matches part #, but looks like they changed the inductor type in fabrication
      • mon2
        • Dec 2019
        • 14691
        That looks good. Flux it well and remove it and swap with the blown device. Sometimes, IC vendors will create a low current switching power supply and this will require the presence of a ferrite bead / inductor. We have many designs where the silicon vendor has applied a 1v2 or 0v9 buck regulator. If you are 100% sure that others have bridged this component then you can proceed at your own risk to do the same. This implies that the part is used only for EMI filtering and not as a buck regulator.
        • mrkmpn
          Need help replacing blown ferrite inductor (I think)
          by mrkmpn
          After installing a replacement screen, the backlighting went out and I discovered what I initially thought was a blown fuse. I reconnected the cracked screen and bridged the "fuse" with tweezers and the backlight came on, so I tried the same thing with the replacement screen and the tweezers just sparked, no backlight came on, and the "fuse" was damaged even more. (And yes, the screens were the same model number. I have received an RMA for the screen already)
          The reason I think it was a ferrite inductor is that 1st, it didn't look like a fuse I'd seen before,...
          06-07-2022, 03:52 PM
        • Reintar
          Dell Inspiron 15 7567 (LA-D993P) - No power after replacing blown inductor and shorted mosfet advice needed
          by Reintar
          First of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
          One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...
          08-30-2024, 06:13 AM
        • pjzz2000
          Blown Inductor - HP Envy 17 - J184NA
          by pjzz2000
          Hi
          Totally new to this website/forum, so apologies if not the appropriate place to ask, but.....
          I'm trying to diagnose my son's laptop motherboard.
          Power jack led on, power button led on, but I think post fails. CPU cold and no voltage around CPU graphics card.
          I start to suspect power rails, or PCH or CPU.
          I did a close visual check and find an inductor that looks in a sorry state, next to what I think might be the PCH. I can only see 2R2 I (or L), but from reading, this is not enough to identify the various specs required to get...
          01-28-2024, 10:39 AM
        • swerg
          Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
          by swerg
          Hey everyone,
          I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
          I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
          I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
          06-06-2024, 03:39 PM
          Corsair CX750M [Model 75-002019] - burned output toroid inductor
          by momaka
          Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
          So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
          09-19-2021, 08:44 PM
