MacBook Air A1466 820-00165 Charging Issue
This topic has been answered.
  • DominikPechac
    Still learning
    • Jan 2019
    • 7
    • Czech Republic
    I have a problem identifying a problem on this MacBook Air A1466 with board 820-00165.
    A customer came in with a problem, the laptop was not charging. Otherwise, it works fine - runs from a battery without an issue. The battery is original, the customer also provided his original charger.
    However, when I was diagnosing the issue, I turned the laptop off, checked the board, etc. When I put everything back together, the laptop was charging (I inserted the charger and then turned the laptop on). After unplugging the charger and plugging it back, it doesn't charge anymore. Not even from the power supply.
    So, the laptop does charge if the charger is put in before the laptop is powered on, charging works perfectly. However, if I unplug it and plug it back, it doesn't charge.
    I'm stuck with ideas what to check now,can anyone give me a hint on what to check?
    Thanks a lot!
  • Answer selected by DominikPechac at 04-05-2024, 09:11 AM.
    mon2
    • 14693
    How many charge cycles on the battery?
    What is the led color on the MagSafe adapter cable head when mating with the logic board?
    Locate the 3v42 regulator in the schematics. The Vin to this regulator is fed through a common cathode dual diode. Carefully measure the voltage to ground of the cathode (Vin) going into this 3v42 regulator.
    If ok, this voltage should be the higher of the 2 voltage inputs. Post the measurement without the adapter then mate the power adapter and measure again.
    • mon2
      • 14693
      • DominikPechac
        Still learning
        • Jan 2019
        • 7
        • Czech Republic
        Hello, thank you for your fast reply. When measuring the diode, I found that the 4.7 ohm resistor value is not 4.7. Replaced it, now it seems to be working as it should.
        Thanks a lot!
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck β€” hoping someone here can shed some light.
          πŸ›  Original Issue
          The machine initially wouldn't negotiate 20V over USB-C β€” stuck at 5V.
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • dimis1975
          Macbook A1466 2014 not charging with macsafe 2 charger
          by dimis1975
          I have a macboook air a1466 that stopped charging the battery.
          BAT PINS: with or without ADAPTER IN
          1- GND
          2- GND
          3- GND
          4-0V sense pin
          5-3.42V
          6-3.42V
          7- 8.4V
          8- 8.4V
          9- 8.4V
          AC Adapter plugged in: after a lot of of hours some times start charging
          No BAT Connected- Green to Orange
          AC Adapter plugged in: BAT Connected- no light
          The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
          Any ideas what’s wrong please?...
          08-05-2025, 03:43 AM
        • echothegamer
          Macbook A1466 dies when charger disconnected
          by echothegamer
          Hello all,
          Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
          Details:
          Macbook 13' A1466
          Board (820-3209-A)
          Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
          Pictures below of Boardview and schematic...
          I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
          It's an older model and it is very likely that battery has become...
          10-28-2023, 12:00 PM
        • sherifu
          Macbook Air A1466 Emc 3178 No light charger after spilling liquid
          by sherifu
          Hello guys, i have an Macbook Air A1466 Emc 3178, board number 820-00165-A and i encountered following problems. At first no light, no power..after opening and cleaning the LCD socket(Red dot under LCD plug and also Orange dot near wifi card)..got light on charger, fan working and chime...Tried several times and working, then short time after dead...next day work again for short time...after removing the board and cleaning the back(rust on components) with alcohol and soft brush, one of the resistor is gone and no power ..I want to change 5 (buy from China) of them (1 missing and 4 bot looking...
          03-26-2024, 04:54 PM
        • Johndill
          Dell Inspiron 7567 LA-D993P odd charger issue
          by Johndill
          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
          Here are the tested scenarios:
          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
          2. With the laptop off, plug in charger (LED says on) & the front charging...
          11-16-2022, 10:55 PM
