MacBook Pro A1707 Graphics issue.
  • janoszw
    • Apr 2015
    • 10
    Hi, I'm having a problem with my MacBook Pro A1707.
    There are graphics glitches all over the screen.
    I took a screenshot, so it's not a screen issue, but either the graphics card or VRAM chips.
    Has anyone had this issue before? I don't want to replace unnecessary components.
    The system is otherwise quite stable, it's just a visual problem.
    Thanks.
  • janoszw
    • Apr 2015
    • 10
    I downloaded the gfxCardStatus app, and it seems that the issue only occurs with the integrated graphics. There are no artefacts when using discrete graphics.
    • mon2
      • Dec 2019
      • 14677
      Can you run Memtest?
      MBP A1707 2017 RAM issue - Badcaps
      • janoszw
        • Apr 2015
        • 10
        Memtest didn't show any errors.
        • mon2
          • Dec 2019
          • 14677
          I can only conclude that the GPU contains onboard local and faster RAM and that MEMTEST is not testing this GRAM.
          On this note, if you are fine to disable the GPU then that is one option. I recall a similar case years ago when VOIP phones were just starting to become popular. Was in Taiwan (Taitronics) and a local mfr pitched these low cost VOIP handsets for ~$60 USD each. Purchased 3 sets to share with our brother in California and proceeded to also test locally. Found that they were quite flaky on the operation but realized that each phone call went through a switch in Taiwan for dialing between handsets. The quality of the phone working or not became more erratic over time. At that time, proceeded to open up the enclosures to apply mild heat onto the SRAM chips we found inside along with a 8051 microcontroller. Everytime we applied this mild heat on the memory devices, the VOIP operation was stable and each handset booted fine. As it cooled down, same set went crazy on the B&W lcd and the boot process. Then we ordered a faster grade of this SRAM we were heating from DK and each handset became solid as a rock on its operation. This excitement lasted for a few limited months as the company folded and killed the service. Take away here but at your risk (my disclaimer), consider to apply a bit of heat onto the GPU to see if the artifacts disappear. Not a solution but was our observation.
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            🛠 Original Issue
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • sofles
            Macbook a1707 2017 model 820-00928 GPU issue
            by sofles
            Hello there
            I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
            I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
            11-21-2024, 05:25 AM
          • CG_Dionysos
            MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
            by CG_Dionysos
            I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
            • Model: A1707
            • 15-inch, Mid 2017
            • 3.1 GHz Core i7
            • 16 GB RAM
            • Radeon Pro 560
            • 1 TB SSD
            • Board number: 820-00928-A
            I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
            Thanks in advance!
            Greetings from Germany...
            09-16-2025, 06:43 AM
          • leonemax81
            Macbook a1707 820-00281 Battery no Power
            by leonemax81
            Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
            08-23-2024, 09:24 AM
          • pcbmaniac
            MacBook A1278 (3115) No PPBUS_G3H Issue
            by pcbmaniac
            Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
            I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
            1. U7000 Measurements:
              • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
            2. Resistors:
              • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
            Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
            • If I also decide to replace the SMC, do I need to order it pre-programmed,
            12-02-2024, 04:12 PM
