hye need forumer help. i got 1 compaq v3000 intel model. when power on with battery the display come. but when pull out the battery and put adapter charger laptop can power on but no display. anyone had face with this problem too? already chekck u4 mosfet and u10 mosfet. pin 123 got 19v but pin 5678 no volt.
					compaq can power on batttery but not by charger
 Re: compaq can power on batttery but not by charger
 ok i will post results here Thanks dj . As i know from dj _ricoh said pin 1 for ACIN pin 3 for DCIN and pin 6 for ACOK. ACIN and DCIN from adapter input . and ACOK from LDO,what means LDO ? and . what are connection do here with display ? seem like shorted cap in that area ?when put adapter no display but ok with battery.Comment
 LDO provide 3.3V for the chip it self in order to set REF voltage and gives voltage to mosfet that charge the battery.
 results first so we can see what is going on Just cook it! It's already broken. Just cook it! It's already broken.Comment
 i got 19.12v on pin1 , 3.08 on pin 3 and 3.27v on pin 6. when power on state pin1 drop to 18.77v , 3.08 on pin3 then 3.27v on pin 6.
 more info i measure volt on U4 mosfet pin 5678 no volt but present volt on gate , 1,2,3 all got 19v.
 u10 also same volt as U4 no volt on source.
 put battery+adapter back also got same reading.Comment
 Assuming...7 Photos
			by PantherDaveHi all!
			by GLISITHi all,
			by Mita99Hi,
 Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
 Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
 Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
- Loading...
