compaq can power on batttery but not by charger
  • sasser
    • Dec 2012
    • 364
    • Malaysia
    hye need forumer help. i got 1 compaq v3000 intel model. when power on with battery the display come. but when pull out the battery and put adapter charger laptop can power on but no display. anyone had face with this problem too? already chekck u4 mosfet and u10 mosfet. pin 123 got 19v but pin 5678 no volt.
  • alihomee
    • Dec 2012
    • 1576
    • malaysia
    Re: compaq can power on batttery but not by charger
    see for charger ic
    • sasser
      • Dec 2012
      • 364
      • Malaysia
      use maxim 8725e. i check voltage at pin 95v 10,11,12,13 no volt
      • dj_ricoh
        • 2073
        you need to focus on PIN 1 , 3 and 6
        post results from those pins
        • sasser
          • Dec 2012
          • 364
          • Malaysia
          ok i will post results here Thanks dj . As i know from dj _ricoh said pin 1 for ACIN pin 3 for DCIN and pin 6 for ACOK. ACIN and DCIN from adapter input . and ACOK from LDO,what means LDO ? and . what are connection do here with display ? seem like shorted cap in that area ?when put adapter no display but ok with battery.
          • dj_ricoh
            • 2073
            post the result here
            • dj_ricoh
              • 2073
              LDO provide 3.3V for the chip it self in order to set REF voltage and gives voltage to mosfet that charge the battery.
              results first so we can see what is going on
              • sasser
                • Dec 2012
                • 364
                • Malaysia
                i got 19.12v on pin1 , 3.08 on pin 3 and 3.27v on pin 6. when power on state pin1 drop to 18.77v , 3.08 on pin3 then 3.27v on pin 6.
                more info i measure volt on U4 mosfet pin 5678 no volt but present volt on gate , 1,2,3 all got 19v.
                u10 also same volt as U4 no volt on source.
                put battery+adapter back also got same reading.
                • dj_ricoh
                  • 2073
                  i hope you get it.
                  IF PIN 3 ACIN its 3.3v over 1.5V , ACOK needs to be Low,
                  ACOK its high when there is no ACIN.
                  get it?
                  if ACIN High and ACOK high the max its FUBAR.
                  • sasser
                    • Dec 2012
                    • 364
                    • Malaysia
                    so solutions is need replace with the new one ?
                    • dj_ricoh
                      • 2073
                      yee
                      • sasser
                        • Dec 2012
                        • 364
                        • Malaysia
                        already replace but still the same. all volt also same
                        • dj_ricoh
                          • 2073
                          same voltage?
                          • sasser
                            • Dec 2012
                            • 364
                            • Malaysia
                            yes pin1 i 19.12v 3.08 on pin 3 and 3.27v on pin 6. on psu read current in 0.7200.
                            • dj_ricoh
                              • 2073
                              pfff
                              insert the bat in and check the pins from the battery(socket)
                              • sasser
                                • Dec 2012
                                • 364
                                • Malaysia
                                bat pin pin1 11.4v pin2 3.23 v pin 3 3.23v the rest no volt. the i check maxim chip not voltage at pin1 pin3 and pin6
                                • sasser
                                  • Dec 2012
                                  • 364
                                  • Malaysia
                                  current measured only 0.7200A when adapter plug in with laptop power on. this not normal reading.
                                  • PantherDave
                                    by PantherDave
                                    Hi all!
                                    05-29-2024, 02:01 PM
                                  • GLISIT
                                    by GLISIT
                                    01-16-2025, 02:29 PM
                                  • Mita99
                                    Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                                    by Mita99
                                    Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                                    Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                                    Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                                    04-27-2025, 07:20 PM
                                    by sam_sam_sam
                                    03-31-2024, 02:12 PM
