MSI MS-14C4 - No power (MS14C41 Ver 3)
  • tommy97
    • Mar 2023
    • 167
    • United Kingdom
    I'm having a problem with MSI MS-14C4, no power 20v 0.1amp on the reader, no signs of liquid damage, if battery attached there is no difference. Area next to BQ gets very hot as well with PR305, PQ31 Drain 20V, Source 4.2v, Gate 5.2V about 4.1V, PQ30 Drain 4.2 V, Source 0V, Gate 2.2V.
    I've noticed that occasionally 2nd USB port goes to 5v - 0.1AMP, as soon re-connected comes back to 20V 0.1Amp any ideas? I couldn't find any schematics nor boardview.
  • mon2
    • Dec 2019
    • 14662
    Remove all power -> meter in resistance mode (not diode mode). Check the resistance to ground @ PC231. One meter probe @ PC231; other meter probe on the other side of PC231. One side of this capacitor is ground. If this cluster of parts is heating up then someone in this region is shorting and drawing too much current, resulting in heat generation.
    • tommy97
      • Mar 2023
      • 167
      • United Kingdom
      0.8MOhm on PC231, removed PC231 and 2 others next to it, same thing, after removing, when PR next to it is removed board does not heat up, 20v 0.6amp
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        PR305 is current sensing resistor?
        • michoteuber
          • Jul 2018
          • 3
          • Chile
          please someone send boardview
            • 21874
            https://www.badcaps.net/forum/troubl...f-this-section
            • tofik
              MOSFET equivalent K8A60DA
              by tofik
              Hello guys,
              I have a shorted MOSFET K8A60DA with the following characteristics:
              Type Designator: TK8A60DA
              Marking Code: K8A60DA
              Type of Transistor: MOSFET
              Type of Control Channel: N -Channel
              Maximum Power Dissipation (Pd): 45 W
              Maximum Drain-Source Voltage |Vds|: 600 V
              Maximum Gate-Source Voltage |Vgs|: 30 V
              Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
              Maximum Drain Current |Id|: 7.5 A
              Maximum Junction Temperature (Tj): 150 °C
              Total Gate Charge (Qg): 20 nC
              Rise Time (tr): 25 nS
              Drain-Source
              07-19-2023, 05:18 AM
            • Jane
              How do you test MOSFET in laptops ?
              by Jane
              I tried to use this method:
              Testing an N-channel MOSFET:
              Step 1: Discharge the Gate (turn off the MOSFET)
              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
              Step 2: Charge the Gate (turn on the MOSFET)
              Now, place the red probe on the Gate (G) and the black probe on the
              09-27-2024, 03:31 AM
            • gpx
              HP 250 G5 (LA-D704P with a Core i7-6500U) won't POST
              by gpx
              Hi everyone, I am hoping for a little help with an HP 250 G5 with motherboard LA-D704P with a Core i7-6500U. I am new to board repair but keen to learn.
              I am sorry this post is quite long but I was trying to systematically work my way through things.
              I don't know the history of the board – I bought it as part of a job lot.
              I have attached a number of photos of both sides of the board. I cannot seem to find a schematic or boardview online.
              When plugged in to DC power the power LED lights and the battery seems to charge. It will not...
              06-18-2021, 10:39 AM
            • tantr13
              Lenovo Ideapad 5 14ITL05 not powering on
              by tantr13
              This is my first post so I'm hoping to get some help on this awesome forum. As a preface, I'm an amateur at electronics, especially troubleshooting complicated devices like laptops. However, I'm trying to develop a skill for it so I can learn how these devices work and how to repair them without continuing the wasteful tradition of throwing them away and buying new. 🤮
              I've had a Lenovo Ideapad 5 14ITL05 for a few years now, with motherboard LA-K321P. I would never leave it plugged in unless I was using it, and always turned it off after I was done, but last week...
              06-28-2024, 06:28 PM
            • survivalbloke
              Acer Predator PT516 - no power, drawing 2.8a lid closed, battery connected
              by survivalbloke
              This is a Predator PT516-51s laptop, serial number is rubbed off. Board is LA-L211P Rev 1A. Charging light is on, machine draws 2.8a lid closed. If I press the power button, I get a blue power light indicator about 5 seconds, then it goes back off. I pulled the board to discover that with battery and AC connected, battery mosfet 1 light up under thermal. I then verified a short to ground on battery mosfet 2 source. If I inject voltage there, my PSU goes to current limit, but nothing illuminates on the board - anywhere, either side. I removed mosfet 2 but still have the ground short at source....
              10-21-2025, 01:35 PM
