Well I am dumb to buy a faulty water damaged motherboard from ebay and i need help :)
  • Satvik Hardat
    • Mar 2024
    • 38
    • India
    yesterday i bought this Click image for larger version
    I was not high on caffeine but the specs we nice-
    • Processor: AMD Ryzen 5 4600H 6 x 3 - 4 GHz, Renoir-H (Zen 2)
    • Graphics adapter: AMD Radeon RX Vega 6 (Ryzen 4000/5000)
    • Ram: 16gb DDR4
    so i bought it now i need schematics and help trouble shooting this all i saw is this burned cap idk what the value is, HELPClick image for larger version
  • Satvik Hardat
    • Mar 2024
    • 38
    • India
    It was 22.5$
    • mon2
      • Dec 2019
      • 14720
      Start with using IPA (alcohol) with cotton swap to clean up all the areas with the white puss / puke / corrosion on the PCB. Also clean up this area which appears to have a burnt capacitor. Then post a clear but close up picture of the logic board.
      • Satvik Hardat
        • Mar 2024
        • 38
        • India
        Ok I'll do that 🙂
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          i never buy mainboard only unless i have all other component to fully test the board. as suggested clean with ipa, and check if that cap is shorted. if so remove it and measure again.
          • rddube
            Aspiring Expert
            • Jun 2013
            • 954
            Wait, before you clean it do post nice clear and crisp photos (sorry to say, but your photos are blurry) so that we can help you identify the areas to fix. From the blurry photos you posted, I spotted a few spots that look suspicious. see attached. Only after having identified all areas both sides that might have been affected will you have any hope of getting this thing back to life. After having identified all areas (which we can help you with with some decent photos) then do what Mon2 suggests.
            • Satvik Hardat
              • Mar 2024
              • 38
              • India
              ok lemme tell something else i did
              • Satvik Hardat
                • Mar 2024
                • 38
                • India
                See the thing is when I received the motherboard it was somehow showing light. And I was really happy but then I saw the capacitor smoking and after few second. the motherboard turn off and I remove it that capacitor. but after that the motherboard never showed any light And then at my try at replacing that capacitor. I removed another one. then again Is started showing light? I don't know how then the third and the last capacitor on that the decoupling rail in that VRM started smoking but i removed the power asap so now it should show light but start the capacitor to smoke again idk why pls help, sharing pics in 5 min
                • Satvik Hardat
                  • Mar 2024
                  • 38
                  • India
                  photos- Click image for larger version
Name:	WhatsApp Image 2024-03-27 at 20.26.44_79e84b84.jpg
ID:	3243201 Click image for larger version
ID:	3243208 Click image for larger version
Name:	WhatsApp Image 2024-03-27 at 20.27.31_7bc9f19c.jpg
ID:	3243202 Click image for larger version
Name:	WhatsApp Image 2024-03-27 at 20.27.30_c27ad51b.jpg
ID:	3243203 Click image for larger version
Name:	WhatsApp Image 2024-03-27 at 20.27.33_2f1f631c.jpg
ID:	3243204 Click image for larger version
Name:	WhatsApp Image 2024-03-27 at 20.27.41_db6650ce.jpg
ID:	3243205 Click image for larger version
Name:	WhatsApp Image 2024-03-27 at 20.27.34_5c561ff0.jpg
ID:	3243206 Click image for larger version
Name:	WhatsApp Image 2024-03-27 at 20.27.47_d4f5f9a4.jpg
ID:	3243207 Click image for larger version
ID:	3243209 Click image for larger version
                  • Satvik Hardat
                    • Mar 2024
                    • 38
                    • India
                    Pls help as soon as possible
                    • dellxps15
                      • Feb 2014
                      • 1598
                      • italy
                      all the latest pictures are after board got cleaned ? clean with ipa and if necessary apply flux and hot air, but u should spot if some component is still ok or need to be removed/replaced by measuring if it's shorted or not.
                      green spot just clean and check if shorted, while red spot clean and maybe rremove component to see if it's corroded also under it. more important on ic the mosfet.
                      before all always check for shorted marked component before take any action. if a capacitor looks bad but no short u can leave it that way. if an ic is corroded, u should check datasheet and see what each pin is for.
                      • Satvik Hardat
                        • Mar 2024
                        • 38
                        • India
                        I checked with multimeter now and all the three caps are bad or shorted with no resistance across them Click image for larger version
ID:	3243473 so I removed all 3 so should I power it on or not now.(Now I saw no short using multimeter) And one more thing the cpu vrm caps have a minimal 6 ohms resistance across are they fine because the reading comes after some time I think because they are large electrolytic caps
                        • Satvik Hardat
                          • Mar 2024
                          • 38
                          • India
                          Some how it works nowwwww. ))))), i see no smoke or shorts 5v, 3.3v, 1.8v are there but unable to fine voltages on cpu vrms maybe i needa short the power button connector but ain't able to find any teardown for this specific model
                          • dellxps15
                            • Feb 2014
                            • 1598
                            • italy
                            many laptop after removing power will cycle 2-3 times before giving picture. did u clean well the 2 corroded ic marked red in my picture ? good work till now.
                            6 omh on cpu are fine.
                            • Satvik Hardat
                              • Mar 2024
                              • 38
                              • India
                              uhm one more thing is it fine for 5v rail sit at 5.8v and 3.3v at 3.6v?
                              • Satvik Hardat
                                • Mar 2024
                                • 38
                                • India
                                before startup or shorting the power button pins (and i dont know the reading after powering on cuz i am still looking for the power button jumper near ec chip)
                                • Satvik Hardat
                                  • Mar 2024
                                  • 38
                                  • India
                                  Now even higher 5v at 6.12 and 3.3v at 4.02v
                                  • dellxps15
                                    • Feb 2014
                                    • 1598
                                    • italy
                                    check multimeter battery... looks like it's bad reading
                                    • Satvik Hardat
                                      • Mar 2024
                                      • 38
                                      • India
                                      Hmm ok it has also started showing low battery sign.
                                      • Satvik Hardat
                                        • Mar 2024
                                        • 38
                                        • India
ID:	3243692 Now this is last i promise you see that connector one of its pins are the power_btn that goes to ec chip and idk what should i short to ground
                                        • RetroComputingGrotto
                                          Water Damaged Toshiba 48L1435DB
                                          by RetroComputingGrotto
                                          I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
                                          The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
                                          10-07-2024, 08:23 AM
                                        • rzsn
                                          water damaged G513I
                                          by rzsn
                                          Hello friends, so I have got a "water damaged" (or cola/beer/coffe .. something dark and sticky) G513I system - which has the board and schematics from this thread. After cleaning up all the visible sticky residue with water and detergent (thankfully mostly on the top/keyboard side), I have a partial success. IPA was of no use for cleaning this.
                                          Using a bench power supply on the DCIN jack (as it seems that the PSU keying pin is not wired at all - series resistor R6003 is not populated), and using a shoring wire for the power button (either pin 5 on CN251 keyboard, or one...
                                          12-22-2024, 09:02 PM
                                        • phantomEVO
                                          [help]820-01521 WATER DAMAGED
                                          by phantomEVO
                                          HELP! audio board+its flex+powerbtn flex water damaged (an hole on audio board)!!! chnged both, but i have 5v on both ports:
                                          https://files.fm/f/6gjpqyjw3q
                                          here some measurements
                                          ppbus_g3h 12,29v
                                          PP3V3_G3H 3,29v
                                          pp3v3_upc_xa_ldo pp3v3_upc_xb_ldo 3,27v
                                          PP1v8_UPC_XB_LDOD PP1v8_UPC_XA_LDOA 1,8v
                                          PP1v8_UPC_XA_LDOD PP1v8_UPC_XA_LDOa 1,8v
                                          PP1V1_UPC_XA_LDO PP1V1_UPC_Xb_LDO 1,1v
                                          with battery connected, as soon as i connect the cable, i see direclty 20v, but stuck at 0,0250
                                          10-24-2025, 04:23 AM
                                        • estabilito
                                          Dell Latitude E5590(La-f411p) water damaged
                                          by estabilito
                                          I have water damaged Dell Latitude E5590 around charging ic.
                                          Laptop was dead but i replaced some components like capacitors, resistors, resoldered charger(intersil 9538h) but traces under PQ904 dual mosfet(AOE6936) was burnt.
                                          I rebuilt traces and both mosfets(PQ904 and PQ905) and after all this work laptop started turning on.
                                          I dont have battery so i want to be sure if laptop behaviour is normal before buying.
                                          On PL902 i have weird voltage around 5Volts, on battery socket voltage looks normal - 13.5v.
                                          Is this voltage on pl902 normal?...
                                          03-08-2025, 06:22 PM
                                        • abajor
                                          A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
                                          by abajor
                                          Like title says A2141 came in with Water Damage, customer desperately wants the data.
                                          The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
                                          I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
                                          That said after cleaning up the...
                                          12-21-2024, 07:16 PM
