Apple 820-000923-A not charging
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3631
    • slovakia
    Hello.
    Have this Apple with board 820-000923-A that not charging. one port was not registering power. found low rezistance on USB_TA_CC1. after chip UB300 desolder, rezistance change to normal. other ports have still only 5V but now goes from 512mA to 123mA.
    can charging work without this ic or all chips must be placed?
    any hint what to check next?
    dont have SN because it is whole wrapped
  • mon2
    • 14753
    Check the ldo rails on each ace controller (cd3215/cd3217). Each ace must be working for 20v.
    • a_p3rson
      Apple Watch Charging Controller Schematics / Boardview - 820-02601
      by a_p3rson
      Hi there,
      I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
      You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
      This daughterboard uses an interesting...
      04-21-2025, 11:41 PM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • Thomasraud
      Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
      by Thomasraud
      i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
      QUOTED
      -It works on charger (without battery connected-only charger)
      -It works on battery (without charger connected-only battery)
      -& it also works when plugged in battery & charger, but it's not charging the battery
      //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
      and..
      QUOTE
      The IC cannot maintain the input current level
      06-28-2022, 06:47 PM
    • fisha
      Apple macbook Pro Retina A1398 Battery not charging
      by fisha
      Hallo everyone, my A1398 do not charging the battery and the battery also do not bin recognized. I did all the reset work, SMC reset and all the other reset options but nothing helped. on the SMC at pin 2 (DCIN) there are 20,4V coming in. at pin 16 (BGATE) which goes to the Q7155 Gate there are only 11,43V. at the pin 1,2 and 3 on the Q7155 (Source) there are 12,23V. Cap C7126 is not shorted. As I understand, the gate voltege have to by higher then the source voltege for the gate to clous so the battery can be charging, am I right? can someone help me with this? I guess that manny models are working...
      07-20-2024, 08:39 AM
    • Scoff
      HP Probook 470 G4 - Power and Charging Problem
      by Scoff
      Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
      Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
      07-03-2023, 09:28 AM
