Dead 2018 Macbook Pro A1990 820-01041-07 stuck at 5V 0A
  • pcash0007
    • 12
    First time looking at a logic board this closely, learnt enough from videos and forums here to be dangerous
    I was doing a OS update when the screen went blank at some point. Does not seem to be in DFU mode (checked using apple configurator).
    PPDCIN_G3H is 5.16V​
    PPBUS_G3H is 0.045V
    Resistance between TP_PPBUS_G3H and ground is 23.8 Ohms (which seems low)
    F7000 and F7001 seems fine.
    From what I learnt seems like there might be short on the down side on PPBUS_G3H.
    Is injecting low voltage and see what heats up the next step(I have access to a friend's thermal camera)? On that note couple of questions...Why do we have to inject voltage directly at PPBUS_G3H to find the blown capacitor, If the capacitor is shorted, why doesn't it get hot with the USB-C plugged in, does something else sense this and shut the power(that might explain 0A draw)?
    I'm thinking of getting a variable power supply, in the meantime can I use low voltage adapter 2/3V to apply power to PPBUS_G3H to see what heats up?
    Thank you.
  • reformatt
    • Feb 2020
    • 1507
    Check edges of the board near fan intakes first before any voltage injection. Usually corroded capacitors, most common one on this model is C9081 going short.
    23 ohms is a worry though and usually indicates a shorted DRMOS near the CPU. Check resistance to ground on the coils near the CPU. You can also measure between PPBUS_G3H and each CPU coil to see if you have 0 ohms to eliminate whether any of the DRMOS have gone short.
    Edit: Also disconnect external things on the board like trackpad. Have had a bad trackpad cause the same issue, read about 10 ohms to ground on PPBUS IIRC.
    • pcash0007
      • 12
      Thanks reformatt.
      Visually everything looks good including the C9081.
      Few questions...I'm having tough time finding where the CPU coils are, help please, a part# or TP# or something I can lookup in FlexBV.
      • mon2
        • Dec 2019
        • 14673
        Coils in the boardview files will have a "L" prefix.
        • pcash0007
          • 12
          Thank you mon2.
          Looks like the coils around the CPU are L72xx, L73xx, is that right? If so, the resistance between PPBUS_G3H and these coils is between 6 - 14 ohms
          LA340, LA640, LA650 - 6.3 onms
          L7211, L7221 and L7231 - 8.2 ohms
          L7410, L7420 - 13.9 ohms
          Also the measurements in my previous post and this one are with the board removed with no other peripherals attached.
          Thank you.
          • mon2
            • Dec 2019
            • 14673
            Yes. No way to sugar coat this so need to rip the bandaid off. The CPU is very likely dead. The high side mosfet in this low voltage rail is leaking so the low voltage device (ie. CPU) has been spiked by the PPBUS_G3H voltage which would have been ~12-13 volts. The proof is in the low resistance between the ISL PPBUS_G3H voltage producer leg to these multi-phase power supply rails.
            • pcash0007
              • 12
              Oouch, that does hurt, but it is what it is. Thank you for helping me put this to rest. I'll look around for a replacement logic board.
              • pcash0007
                • 12
                Another question....PP1V8_SLPS2R seems to be the enable for U7000 which makes PPBUS_G3H. PP1V8_SLPS2R has 0V. Is it possible that's why PPBUS_G3H is zero?
                The resistance between ground and the coils near CPU is also very low even lower than PPBUS_G3H and the coils.
                • anhbanxoi
                  • Sep 2021
                  • 180
                  • VN
                  You don't have PPBUS_G3H mean U7000 is not enabled or defective. But first check U6960 area, you will need that power rail up before getting PPBUS_G3H
                  • reformatt
                    • Feb 2020
                    • 1507
                    Originally posted by pcash0007
                    Thank you mon2.
                    Thank you.
                    A non zero value doesn't necessarily mean the CPU is dead. Under normal circumstances, you have a low ohms value to ground on the CPU coils. So with a short or low impedance on PPBUS, total resistance should exceed both in series with each other (as they are linked via ground and assuming you have no DRMOS failure).
                    23 ohms seems too high for a CPU failure. I would expect 0 ohms between a coil like L7211 or L7221 and C7262 if a DRMOS had shorted. Make sure everything else on the board is disconnected when you do these measurements. And any low resistance on PPBUS_G3H like that will cause the power rail to shut down.
                    I use voltage injection/thermal camera to verify it is a DRMOS failure, and remove the DRMOS to confirm the short on PPBUS_G3H is removed. Then board is a donor at that point.
                    • pcash0007
                      • 12
                      Thank you reformatt.
                      I think the board is toast. I did not get to check with thermal camera yet, I plan to do it just to experiment and learn.
                      I see that resistance between TP_PPBUS_HS_CPU and TP_PPVCC_S0_CPU is ~9ohms which leads to me to think one of the DRMOS U7210 - U7230 is shorted.
                      To determine which DRMOS is shorted, should I introduce voltage @ one of the PPBUS_G3H fuses?
                      • pcash0007
                        • 12
                        I'm trying to find a replacement board for this laptop. The number of the board is 08-01041-07, I see a lot of 08-01041-A on ebay, are these interchangeable? The year(2018) and model(A1990) match on both the boards. Please Help. Thank you.
                        • anhbanxoi
                          • Sep 2021
                          • 180
                          • VN
                          Yes you can install 2018 A1990 to 2019 A1990.
                          • pcash0007
                            • 12
                            Cool. Thank you.
                            • gbuniva
                              • May 2019
                              • 17
                              • argentina
                              Sorry I posted my concern here because was the only way.
                              I have a 820-01041-A that works only when battery is disconnected.
                              No signs of liquid damage, board looks good.
                              The only way that turns on and boots normally into the system is w/o battery and conecting the USB C power cable to the bottom left side connector.
                              Otherway doesn´t turn on.
                              Measures connected to Magsafe and w/ battery :
                              PPBUS_G3H = 12.50v
                              PP3V3_G3H_T = 3.35v
                              P5VG3S_VSW = 0v
                              CHGR_BGATE = 12.43v
                              PP1V2_AWAKE = 1.21v
                              PP1V8_AWAKE = 1.81v
                              PPVDDCPU_AWAKE = 0.76v
                              PPVDDCPUSRAM_AWAKE = 0.81v
                              PP0V8_SLPS2R = 0.81v
                              PP1V8_SLPS2R = 1.81v
                              PP1V1_SLPS2R = 1.11v
                              SMBUS_3V3_BATT_SCL = 3.02v
                              SMBUS_3V3_BATT_SDA = 3.02v
                              I2C_PWR_SCL = 1.86v
                              I2C_PWR_SDA = 1.86V
                              Any sugestions will be appreciated.​
                              • mon2
                                • Dec 2019
                                • 14673
                                These look low. Should be ~3v3 for each.
                                Confirm the voltage to ground @ L6960 / L6961. Then remove all power and place the meter into resistance mode (not diode). Then check the resistance across R6934 and again for R6935. Each should be ~0 ohms.
                                P5VG3S_VSW =0v
                                remove all power and place the meter into resistance mode (not diode). Then check the resistance of this rail. Something wrong here. Need to confirm the resistance and also that the ENABLE pin for this regulator is present (P5VG3S_EN_R = pin # 4)​
                                • pcash0007
                                  • 12
                                  Starting a new thread, the concern on the original thread changed and did not want to mix them up, continuation of
                                  https://www.badcaps.net/forum/troubl...0a#post3256393.
                                  I applied 2v(1v did nothing) to F7000 and noticed 2.5amp draw. The hotspot was C6553. I did not see any increased heat at any of the DRMOS near the CPU, should I be applying voltage at a different place to test the DRMOS?
                                  Thank you.
                                  • mon2
                                    • Dec 2019
                                    • 14673
                                    Excellent. Flux and remove C6553 off the board. Then measure the resistance to ground again on F7000. Is the resistance much higher now? If yes, attempt to power up the board again if this is the only fault.
                                    • gbuniva
                                      • May 2019
                                      • 17
                                      • argentina
                                      Hi mon2, thank you for your assistance:
                                      L6960 = 3.42V constant
                                      L6961 = 2.4 - 2.8 v fluctuating all time
                                      R6934 = 0 ohm
                                      R6935 = 0 ohm
                                      P5VG3S_VSW rail in resistante mode gets 350ohm and infinity like a diode
                                      Now something strange just happened, when a was about to measure P5VG3S_EN_R = pin # 4 with the battery connected, the Mac turned on (never did before)... now I have it running and charging the battery from 0%.... I´ll keep it ON and charging until 100% to see what happens and report you back.​
                                      • pcash0007
                                        • 12
                                        My apologies for the cross posting, I created a new post with a link to this but the two seem to have gotten merged somehow
                                        I remove C6553 and the resistance between F7000 and ground increased significantly into mega Ohms. Now when the power is connected after negotiation, it jumps up to 20v , 1A. I'm waiting for the replacement capacitor, once that is in place, I'll put the board back and see if it boots up.
                                        Thanks for all your help so far.
                                        • robka
                                          MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                                          by robka
                                          my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                                          I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                                          The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                                          After that the Macbook was dead. It isn't charging anymore.
                                          The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                                          03-02-2024, 02:58 PM
                                        • DATATECH85
                                          Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
                                          by DATATECH85
                                          I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
                                          The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
                                          I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
                                          However, I can't work out exactly why I don't have the PPBUS_G3H rail.
                                          Here are the values...
                                          07-24-2024, 06:34 AM
                                        • Fisher8865
                                          MacBook Pro A1990 stuck at 5v .592 amps
                                          by Fisher8865
                                          Hi guys
                                          I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
                                          05-30-2024, 07:36 PM
                                        • mr.Data
                                          Macbook A1990 stuck on logo
                                          by mr.Data
                                          This Macbook Pro 2018 boots up and then gets stuck on the logo.
                                          All the normal methods of resetting this Macbook have been tried but do not work.
                                          I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
                                          Any help would be greatly appriciated....
                                          04-18-2024, 11:51 PM
                                        • alfredodinolfo
                                          MacBook Pro 2019 (A1990)
                                          by alfredodinolfo
                                          mb code:820-01827-A;
                                          sn:C02Z349ALVDR;
                                          i9 32GB Ram 1TB
                                          Hi, I found short on one of 6 black nand (total 1TB).
                                          i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
                                          I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
                                          macbook with A2141 configuration run on recovery but don't complete it.​
                                          anyone can help me?
                                          05-26-2025, 09:27 AM
