Dead 2018 Macbook Pro A1990 820-01041-07 stuck at 5V 0A
  • mon2
    • 14673
    Excellent. You should be ok with powering up without having this one capacitor. The logic boards are often fitted with a group of bulk caps to assist each other. Respectively, the board will not halt the operation if one cap is missing. As long as there are no other shorted caps, you should be fine to test the board.
    • pcash0007
      • 12
      It's alive! Thank you so much for all your help.
      Apple wanted $400+ to replace the logic board, ebay had it for $200+ but at the end it ended up being a $5 fix for capacitor + shipping. All thanks to this forum and the wonderful contributors. šŸ™
      • robka
        MacBook Pro 2018 - A1990 Dead - not charging - only 5V
        by robka
        my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
        I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
        The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
        After that the Macbook was dead. It isn't charging anymore.
        The USB-C Port where the charger was plugged is burned. Also The Cable and the...
        03-02-2024, 02:58 PM
      • DATATECH85
        Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
        by DATATECH85
        I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
        The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
        I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
        However, I can't work out exactly why I don't have the PPBUS_G3H rail.
        Here are the values...
        07-24-2024, 06:34 AM
      • Fisher8865
        MacBook Pro A1990 stuck at 5v .592 amps
        by Fisher8865
        Hi guys
        I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
        05-30-2024, 07:36 PM
      • mr.Data
        Macbook A1990 stuck on logo
        by mr.Data
        This Macbook Pro 2018 boots up and then gets stuck on the logo.
        All the normal methods of resetting this Macbook have been tried but do not work.
        I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
        Any help would be greatly appriciated....
        04-18-2024, 11:51 PM
      • alfredodinolfo
        MacBook Pro 2019 (A1990)
        by alfredodinolfo
        mb code:820-01827-A;
        sn:C02Z349ALVDR;
        i9 32GB Ram 1TB
        Hi, I found short on one of 6 black nand (total 1TB).
        i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
        I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
        macbook with A2141 configuration run on recovery but don't complete it.​
        anyone can help me?
        05-26-2025, 09:27 AM
