Acer Nitro AN517-52 FH51M LA-J871P Works on battery only. Won't charge.
  • mon2
    • Dec 2019
    • 14677
    Review the middle black resistor that is near the bottom side of pub1 in the picture.
    Markings are 000. Is this resistor with a solder blob across the pin to the part on the right side? Appears to be with a hunk of solder.
    • gadgettree
      • Feb 2022
      • 15
      You have a keen eye, I missed that. Yes those two components were bridged at the top there. I have removed the bridge with wick and flux.
      Laptop still does not turn on or charge. Would that bridge have damaged the charging ic?
      • madjid911
        • Dec 2016
        • 412
        • France
        Hello, I had exactly the same problem as you, everything was good resistance and voltage (ACDET 2V6, REGN 6V, VCC 20v, ACOK 3V3) but no 20v at the pqb3 and pqb4 output, thanks to you I was able to check everything and repair the laptop, for my part, I had a short on a capacitor, once replaced I had the 20v but the mosfets did not close, after seeing this post, I checked everything like you, I had PB24 poorly soldered (because I had replaced it), there was missing solder on pin 3, after having resoldered it, the laptop loads and turns on correctly.
        From what I see in your photo of BQ24, you have the same problem as me, it looks like, looked at your pin 3, it is missing some soldering​
        • mon2
          • Dec 2019
          • 14677
          Agree with the last post and adding another area to review for possible shorts. Best to flux each area and hot air them. This should allow for the solder to flow into place. If required, use desolder braid to remove the excess solder.
          • martin83
            Acer nitro 5 AN55-515 fh51m LAJ871P no picture
            by martin83
            Hello everyone.
            I'm here to ask for help troubleshooting an issue with my Acer Nitro 5 An55-515. Board number fh51m LAJ871P .
            The laptop turns on without any image, and after inspection, I noticed the 1.2V voltage was reading 8V spikes. The PQM1 MOSFET's gate was shorted to the source.
            I replaced PQM1, PQM2, and PUM1. After turning on the machine, the 1.2V voltage appears correctly for about 1 minute, but after that, PQM1 shorted again. The MOSFET and controller assembly has already been replaced twice and continues to blow. I can't understand what's going on. I should also add...
            07-14-2025, 06:31 AM
          • Jane
            How do you test MOSFET in laptops ?
            by Jane
            I tried to use this method:
            Testing an N-channel MOSFET:
            Step 1: Discharge the Gate (turn off the MOSFET)
            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
            Step 2: Charge the Gate (turn on the MOSFET)
            Now, place the red probe on the Gate (G) and the black probe on the
            09-27-2024, 03:31 AM
          • irfan karatela
            MOSFET no voltage at gate Quanta G7HA DAG7HAMB8EO
            by irfan karatela
            I'm working on a HP Pavilion Laptop Model 15-eh1508sa that is missing 19v. I've looked at the schematics and want to know what conditions the ISL9238C checks before it enables the gate for MOSFETs PQ8200 and PQ8201,
            I havent found any shorts on the board.
            I get 19v at +PRWSRC but around 1.7v at the Drain of PQ8201(+vin)
            On Page 82 of the attachment. Link to schematic - https://www.badcaps.net/forum/troubl...ilion-laptop-p...
            01-20-2025, 07:15 PM
          • redbaron1007
            Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
            by redbaron1007
            I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
            Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
            09-09-2025, 11:10 AM
          • tofik
            MOSFET equivalent K8A60DA
            by tofik
            Hello guys,
            I have a shorted MOSFET K8A60DA with the following characteristics:
            Type Designator: TK8A60DA
            Marking Code: K8A60DA
            Type of Transistor: MOSFET
            Type of Control Channel: N -Channel
            Maximum Power Dissipation (Pd): 45 W
            Maximum Drain-Source Voltage |Vds|: 600 V
            Maximum Gate-Source Voltage |Vgs|: 30 V
            Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
            Maximum Drain Current |Id|: 7.5 A
            Maximum Junction Temperature (Tj): 150 °C
            Total Gate Charge (Qg): 20 nC
            Rise Time (tr): 25 nS
            Drain-Source
            07-19-2023, 05:18 AM
