Panasonic CF-20
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1352
    • France
    Panasonic CF-20
    I'll come back with that. I started here but it wasn't the right place
    because it's not a bios or password problem
    https://www.badcaps.net/forum/troubl...87#post1866387
    Originally posted by Maxpower3
    blackscreen, no boot, no backlight after save and exit in bios setup.
    just led power on/off react
    I have tried several bios here, none have worked so far
    I think it's dead, even the USB key died at the same time as the computer.
    Just the lights power and beep when it turns off
    News:
    I noticed that the motherboard boots when the screen is unplugged.
    If I connect HDMI or LCD, the motherboard no longer triggers any reaction.
    On the other hand, if I unplug the screen and the HDMI, the keyboard responds with caps lock and activity on usb key.
    The backlight works if I force it. Pwm LED 0v and enable 3.3v LED.
    I don't think the screen has a problem
    I think I should look into display management around the PS8407A or CPU
    what do you think?
    Are there any diagrams?
    edit: PS8407A /1629B/ wg1219lm remplaced same
    if I connect after boot HDMI, it does not restart after a ctrl alt del
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1352
    • France
    I had two cards that didn't work
    the first mentioned above and another that did nothing just consumption and no reaction.
    I exchanged several components to see the reactions?
    Now, both cards work,
    I noticed a lack of solder on 2 chips and I reflowed this area.
    the first time, I thought it was heating up the processor and I was lucky thanks to the reflow.
    but did not last.
    so I have reflow only it's 2 chips.
    The 1st card worked again (the one that did nothing)
    I then on the 2nd (starts only without screen).
    it also works again now!
    Is this a stroke of luck or will it hold?? to see over time
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • Chrissygizmo
      Panasonic TX-48CX350B backlights but white screen , blank screen
      by Chrissygizmo
      Hi all, I’ve got a problem I hope someone can help me fixi.
      I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
      01-11-2025, 03:18 PM
    • Alicat
      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
      by Alicat
      Stopped by this site trying to fix my parents Panasonic Plasma TV.
      Model number is TH-50PZ85U
      Power comes on and the red power light stays on solid.
      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
      I also hear a few clicks.
      I also think my parents said there was a thunderstorm and the TV failed after that.
      Section 6 in the service manual talks about power and no screen,...
      10-30-2024, 10:09 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
