Panasonic CF-20 Bios Password
  • pipo7169
    • May 2016
    • 27
    • usa
    could anyone help please remove cf-20 bios password?
  • peste
    • Dec 2016
    • 12786
    • ROMANIA
    Re: Panasonic CF-20 Bios Password
    try..
    • pipo7169
      • May 2016
      • 27
      • usa
      thank you will try
      • liteace
        • 4
        • Spain
        Toughbook CF-20
        Ive got 2 Toughbook CF-20, 1s a Mk1 the other a Mk2, Ive never put passwords in either of them, added a new SSD to Mk2 and also need to switch off mobile/sims modem and its asking for password, the bios is the the winbond 25q128, if I post the dump here can anything be done?
        • peste
          • Dec 2016
          • 12786
          • ROMANIA
          Re: Toughbook CF-20 mk2
          post ... we are loading to help you ..
          • chkintl93
            • Jun 2019
            • 47
            • usa
            Originally posted by pipo7169
            thank you will try
            Just checking. Have you tried the file and how was it working?
            Thank you
            • bluestar77
              • Apr 2015
              • 57
              • sudan
              It's not working on my mk2 cf 20 and here is my locked file bin for cf 20 mk2 can on some unlock it for me
              • hoaca388
                Badcaps
                • Jan 2022
                • 11732
                Unlocked file
                • bluestar77
                  • Apr 2015
                  • 57
                  • sudan
                  Thanks brother i will try and confirm
                  • mohammed mohan
                    • Nov 2017
                    • 196
                    • z
                    Panasonic CF-20
                    Can the file be repaired? No display
                    Mohammed Mohan
                    • nvirginiaboi
                      • Oct 2023
                      CF-20 BIOS Password Unlock Help
                      Need help with BIOS PW unlock
                      Model CF-20G5108VM
                      SN 0FKKC69971
                      I do not know anything about how to get BIOS dump, programmer device etc etc etc. I was given this laptop new from a business partner and the HDD has been wiped. It has the BIOS PW on it upon boot, Just need help to get this thing unlocked. I have not read anything on the forums, I have never done anythign BIOS related besides doing an update. I do not know how to program as I am a Cisco Engineer and thats all I do. If somebody can explain, post pop up pictures, write a manual, anything so I can get this fixed asap will be appreciated.
                      • peste
                        • Dec 2016
                        • 12786
                        • ROMANIA
                        Re: CF-20 BIOS Password Unlock Help
                        Model CF-20G5108VM
                        SN 0FKKC69971
                        you need an SPi programmer... watch a video here as an example..
                        https://www.youtube.com/watch?v=DWWigscuQDY
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1226
                          • France
                          Need help bios for Cf20
                          blackscreen, no boot, no backlight after save and exit in bios setup.
                          just led power on/off react
                          Serial in dump
                          I have tried several bios here, none have worked so far
                          thanks
                          • rex98
                            • Feb 2023
                            • 1277
                            • Mandaue CEBU, Philippines
                            Serial in dump
                            thanks
                            IF this is for unlocking TRY this...
                            • volinakis
                              • Jan 2021
                              • 2728
                              • N/A
                              Serial in dump
                              thanks
                              try
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1226
                                • France
                                Originally posted by volinakis
                                try
                                Same result,Power on/off but no boot and display
                                • volinakis
                                  • Jan 2021
                                  • 2728
                                  • N/A
                                  ok, so I updated ME to 11.8.93.4323, try with ME ver. same as in your dump, 11.0.1.1001
                                  • qayyum786
                                    • Aug 2018
                                    • 1933
                                    • INDIA
                                    try this too
                                    • Maxpower3
                                      Bad Veteran
                                      • Feb 2018
                                      • 1226
                                      • France
                                      volinakis the same, the message didn't go out yesterday.
                                      qayyum786 not tested for the moment
                                      I think it's dead, even the USB key died at the same time as the computer.
                                      Just the lights power and beep when it turns off
                                      • volinakis
                                        • Jan 2021
                                        • 2728
                                        • N/A
                                        for beep codes I use an app on my phone named Lenovo PC Diagnostic. try it, maybe you figure out what hardware problem is.
