820-00840 PP3V3_S5 shorted
  • bamboofuto
    • Nov 2022
    • 53
    • indonesia
    i am working on macbook pro A1708 820-00840 water damage around USB iC U3200 and PMIC U7800. took out U3200 and U7800 but still has shorted on PP3V3_S5.
    i tried to inject 1V and 3.5A but can not detect the heat.
    any suggestion will be appreciated.
  • kevingill
    • Jun 2013
    • 152
    • England
    Do you have a thermal camera?
    • bamboofuto
      • Nov 2022
      • 53
      • indonesia
      unfortunately i dont have. usually for finding short i use my finger and rosin dispenser
      • mon2
        • 14713
        What is the resistance to ground of this shorted rail?
        • bamboofuto
          • Nov 2022
          • 53
          • indonesia
          1.9 ohm short to ground
          • mon2
            • 14713
            It may be bad news but review this thread:
            https://boards.rossmanngroup.com/thr...shorted.52266/
            continue to update this thread with your progress.
            • anhbanxoi
              • Sep 2021
              • 180
              • VN
              Touch the CPU you may feel some heat.
              • bamboofuto
                • Nov 2022
                • 53
                • indonesia
                i touch the pch is a bit warm
                • bamboofuto
                  • Nov 2022
                  • 53
                  • indonesia
                  i touched pch a bit warm..could it be the culprit?
                  • anhbanxoi
                    • Sep 2021
                    • 180
                    • VN
                    I think it's gone. I got the same situation with the same board
                    • bamboofuto
                      • Nov 2022
                      • 53
                      • indonesia
                      sigh.....
                      anyway, thanks for the help anhbanxoi, mon2
                      • reessi
                        Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                        by reessi
                        Hello:
                        I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                        I started on the ACER:
                        Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                        All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                        I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                        10-29-2024, 11:31 AM
                      • Yanleb
                        Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                        by Yanleb
                        Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                        I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                        D608, good
                        D618 RF101L4S, good (See warning 1 below)
                        D619 RF101L4S, good (See warning 1 below)
                        D865 RF101L4S, shorted (See warning 1 below)
                        IC464 Inverter HA MC74HC1G14, shorted...
                        03-09-2020, 12:00 AM
                      • modtool
                        HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                        by modtool
                        Hi to all,
                        the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                        I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                        I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                        04-01-2025, 08:22 AM
                      • BalkanBoy
                        Dead Razer Blade 14 2022, shorted CPU?
                        by BalkanBoy
                        today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                        Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                        I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                        Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                        I removed coil and injected 0.7V, it draw around...
                        09-27-2024, 12:44 PM
                      • barry101
                        Apple 820-3662 VCore shorted to ground.
                        by barry101
                        Hi, Would appreciate some help.
                        I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                        Get charger light but no fan spin or chime. No liquid damage.
                        Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                        Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                        With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                        Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                        06-24-2025, 07:34 AM
