rog strix g733qs thinks battery is plugged in even it is removed (power problem)
  • swammyw
    • Apr 2021
    • 66
    • finland
    Hi, i need help with this laptop, laptop freezes when i enable power saving mode but with turbo mode works fine, i removed battery but laptop thinks it is present & charged to 255%
    could this be some voltage leak to battery sensing lines? is there any way to do some test or measures, thanks for help
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Check dc in mosfets for internal short and requirements of the charging ic.
    • mon2
      • 14086
      Also check the voltage to ground of each pin on the battery connector. It is possible that the SMBUS lines (aka I2C) used by the battery pack communication are being shunted to ground due to an ESD event. In summary, there should be some nearby 3 pin diodes used to suppress ESD surges from humans. If either of these dual diodes (in a single package) are defective, the SMBUS lines cannot function properly.
      Post each measurement. Red meter probe to point to test. Black to ground (metal shield is ok). Meter in DC volts (20v or higher scale).
      • swammyw
        • Apr 2021
        • 66
        • finland
        ok, sorry for delay, hw monitor shows 1mwh battery is present even no battery is connected, battery connector pins from left to right, i have no schematic or brdwv
        with battery =(pin1&2 16,7v) (pin3 not used / no wire to battery) (pin4&5 3,2v) (pin6 2,9v) (pin7&8 gnd)
        no battery = (pin1&2 17,4v drops to 0,1v) (pin3 not used / no wire to battery) (pin4&5 3,2v) (pin6 0,3v) (pin7&8 gnd)
        • Shinju
          Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
          by Shinju
          Hey All!
          Long time forum member here with a problematic laptop issue!
          I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
          The laptop would not power on with the new battery installed without the power supply being plugged in.
          When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
          TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
          10-20-2021, 04:58 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • techfreak9356
          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
          by techfreak9356
          09-14-2023, 11:10 PM
          NVDC charger configuration...
          11-05-2024, 03:28 PM
        • serious_electron
          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
          by serious_electron
          Hello Everyone!
          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
          06-28-2025, 02:57 PM
