MacBook Pro A1706 - 820-00239 - No backlight
  • ryogadan78
    • Nov 2021
    • 66
    • Italia
    Hi guys, I have a MacBook Pro (MB 820-00239) with LED panel backlight problems. I haven't seen any oxide damage on the mainboard or other evident problems.
    The problem suddenly occurred after turning it off regularly and putting it in the bag. When I turned it back on, the backlight no longer worked.
    Where can I start testing and measurements to identify the problem?
    I have board view of the mainboard.
    Thanks!​
  • mon2
    • Dec 2019
    • 14681
    1) could be flexgate issue
    2) does the caps key led toggle after a normal boot time? This means the logic board has booted and you are at the login screen.
    3) check if the display is working with a flashlight or phone torch light across the front lcd panel. Can you see any of the usual graphics?
    4) If not, check the voltage to ground of ppbus_g3h. If it is low, remove all power and check the resistance to ground at the same ppbus_g3h fuse.
    Post each measurement .
    • ryogadan78
      • Nov 2021
      • 66
      • Italia
      Hi mon2, thanks again.
      The MacBook comes to the login screen regularly, I can see the usual graphics using a flashlight sideways.
      The flex cable does not appear to be bent or broken, but I could be wrong.
      Can I make any specific measurements on the motherboard related to the voltages that handle the backlight?
      • mon2
        • Dec 2019
        • 14681
        Measure the voltage to ground of the backlight output voltage with the screen connected. This is the same voltage you can measure at the lcd connector on the board or nearby. This should be a suitable boosted voltage to power the backlight led array.
        also, measure voltage of:
        BKLT_EN_R
        BKLT_SD
        • ryogadan78
          • Nov 2021
          • 66
          • Italia
          Hi mon2,
          I could not find a place to measure backlight output voltage. Can you help me (a net point alternative)?
          The other measurements, with LCD connector plugged in, are:
          BKLT_EN_R 0V
          BKLT_SD 0V
          • mon2
            • Dec 2019
            • 14681
            Measure the voltage to ground of:
            I2c_bklt_scl
            i2c_bklt_sda
            with and without the lcd connected to the logic board.
            confirm the pp5v_s0 is present.
            • ryogadan78
              • Nov 2021
              • 66
              • Italia
              Here the measurements with LCD connected to mainboard
              BKLT_EN_R 0V
              BKLT_SD 0V
              I2c_bklt_scl 0V
              i2c_bklt_sda 0V
              Here the measurements with LCD NOT connected to mainboard
              BKLT_EN_R 0V
              BKLT_SD 5.76V
              I2c_bklt_scl 3.68V
              i2c_bklt_sda 3.68V
              • mon2
                • Dec 2019
                • 14681
                You are losing key voltages when the lcd is attached.
                Remove all power. Meter in resistance mode. Measure the resistance to ground of PPVOUT_S0_LCDBKLT with and without the lcd attached. You can measure this resistance at the output inductor/coil or any of the output capacitors that are also on this rail. One meter probe here and other meter probe to ground (metal shield is ok).
                • ryogadan78
                  • Nov 2021
                  • 66
                  • Italia
                  No power connected, Meter in resistance mode (200k)
                  WITH AND WITHOUT LCD attached same measure: PPVOUT_S0_LCDBKLT resistance to ground is over 100k ohm (keeps growing as I leave the tip in measurement)
                  I also measured the voltage at these points and it is 12.8V (with and without LCD attached)
                  • mon2
                    • Dec 2019
                    • 14681
                    Ok. Measure the voltage to ground of pp5v_s0​ with and without the lcd. Check the resistance to ground of this rail as well under the same conditions.
                    • ryogadan78
                      • Nov 2021
                      • 66
                      • Italia
                      Forgive me for the delay but I had health problems.
                      WITH AND WITHOUT LCD attached same measure:​ pp5v_s0 5,08V - 200ohm (resistance to ground)
                      • kevingill
                        • Jun 2013
                        • 152
                        • England
                        Couple more things to check. Is F8400 OK? Do you have a voltage on PPVIN_S0SW_LCDBKLT?
                        Usually it's the backlight driver chip that goes U8400.
                        • ryogadan78
                          • Nov 2021
                          • 66
                          • Italia
                          F8400 is OK.
                          PPVIN_S0SW_LCDBKLT voltage 12.8V
                          • ryogadan78
                            • Nov 2021
                            • 66
                            • Italia
                            Hi mon2, I think you have found the problem once again.
                            Looking carefully under the microscope, I noticed that the U8400 chip has a burn hole.
                            Do you think this is just the problem? Is it easy to change it?
                            Click image for larger version  Name:	TC70.jpg Views:	0 Size:	232.3 KB ID:	3217611
                            • ryogadan78
                              • Nov 2021
                              • 66
                              • Italia
                              1x P8548BOSQ-02 48BO-02 ... 48B0-02 ... LP8548B0SQ LP8548B1SQ LP8548 QFN-24 | eBay Is it the right component?
                              • mon2
                                • Dec 2019
                                • 14681
                                Good job. You guys have found the root fault. Yes, this chip is defective if it has a crack or hole in it. Flux it well and wait till the solder melts to replace it use a slight nudge of the tweezers to remove it. Best to learn the process on a donor board. Yes the part on eBay looks suitable. Be sure to solder back in the same orientation.
                                • ryogadan78
                                  • Nov 2021
                                  • 66
                                  • Italia
                                  Thank you very much. I will update you as soon as the component arrives.
                                  • ryogadan78
                                    • Nov 2021
                                    • 66
                                    • Italia
                                    Hi mon2. The IC arrived today. I removed the old IC without too much trouble, and was about to solder the new one. I had a doubt about the layout because strangely the marker is aligned differently on the two chips (compared to the lettering). I'll send you two photos, do you think it is positioned correctly this way?
Name:	WhatsApp Image 2024-03-04 at 10.05.42.jpg
                                    Original chip
Name:	WhatsApp Image 2024-03-04 at 10.05.40.jpg
                                    New chip just in position (not soldered)​
                                    • mon2
                                      • Dec 2019
                                      • 14681
                                      Wait. The location and part in the original pic is not the backlight controller. The TMP513 is a current sensor. This part is not defective. Place the original TMP513 back onto the board.
                                      you will have to locate the defective backlight ic with the hole in it. Share new pics when ready.
                                      https://www.ti.com/lit/ds/symlink/tm...lsrc%253Daw.ds
                                      • ryogadan78
                                        • Nov 2021
                                        • 66
                                        • Italia
                                        You're right I got confused. I will provide
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • Baspotv
                                          Macbook Pro A1706 no backlight and not booting up
                                          by Baspotv
                                          So recently I got this macbook from a friend of mine. He went to the apple store after his mac did not boot up anymore and they told him that the mac has got a cpu issue. After that he asked me if I could take a look at it and so I did. I got the schematic and boardview from this forum so I started looking for an issue and the only thing I've found is that the capacitors on Page 10 (C1000, C1001,...) all are shorted to ground, so after that I soldered 2 wires to C10G0 and put 2V onto it. After closer Inspection under the Thermal cam the only thing that got hot was the CPU. I followed the path...
                                          10-18-2024, 02:41 PM
                                        • Constantinos
                                          Macbook Pro A2442 820-02098 No image but has backlight
                                          by Constantinos
                                          Hi all
                                          I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                                          He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                                          Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                                          Obviously, he decided against this and gave it to me so that I could have a crack at it.
                                          From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                                          08-24-2024, 09:48 AM
                                        • francescoranchi
                                          MacBook Pro A1909 LCD (no backlight)
                                          by francescoranchi
                                          Hello Everyone,
                                          I'm looking at purchasing a used LCD from ebay for my macbook A1990 2018 15inch which LCD I cracked. Since new / used but working displays cost around 500$ , I found a Grade A+ LCD display for A1990 which has a good price of 110$ but has no backlight.
                                          I would need just to make sure that what I know/my reasoning is correct:
                                          - No backlight means flexgate issue, therefore changingthe flexcable would be enough (I can microsolder to fix the flexgate problem, done it a few times already)
                                          - Seller confirmed its a LCD issue, and not an issue with the...
                                          12-04-2023, 06:46 AM
                                        • tommy97
                                          Apple MacBook A2337 - No backlight
                                          by tommy97
                                          Hi guys, I've got MacBook Air a2337 with no backlight. Once while testing it displayed with the backlight, however after restart problem come back.
                                          The laptop was tested with fully working screen.
                                          PP5v_BKLT_A/B 5V
                                          PP5v_BKLT_D 5V
                                          PP5V_S2 5V
                                          PP5V_SW_LCD 0.4V
                                          P5VS2_PWR_EN 1.8V
                                          P5VS2_BST_R 8V
                                          P5VS2_SW 5V
                                          PPBUS_5VS2_VIN 5V
                                          PPVOUT_LCDBKLT - Doesn't short 0V
                                          FP800 - Both sides 12v
                                          BKLT_EN_R & BL_PWR_EN - around 1.8v
                                          LP800 0.014V On both sides (should be 12? / no short)
                                          UC300 & UP800 Replaced...
                                          12-02-2024, 08:26 AM
