Motherboard: NEW90 L21 No LED Backlight on Display
  • Reech
    • Sep 2012
    • 21
    I can faintly see image on the display with flashlight but screen has no brightness at all. Laptop was dropped; replaced the power jack and LED display cable. Both were damaged and the left hinge was snapped off and flopping around. The LED cable must have shorted something since the display was working prior to the repairs.
    The 2 fuses on back of the LED display check good.
    I could not locate any other fuses on the motherboard.
  • selldoor
    Slow Learner
    • 7870
    Re: Motherboard: NEW90 L21 No LED Backlight on Display
    Double post _ double post
    • dj_ricoh
      • 2073
      first find the schematic
      2nd what voltage you got on the ribbon connector from lcd
      • Reech
        • Sep 2012
        • 21
        Sorry for the double post but I couldn't find any answers to this issue.
        Can't find a schematic. I'll take some pics of the mobo, top and bottom.
        • khaahk
          • Dec 2013
          • 759
          • Estonia
          become friends with google, it took me 30 seconds.
          https://cdn.badcaps-static.com/pdfs/...efbeaa87f2.pdf
          • Reech
            • Sep 2012
            • 21
            Wow the schematic is great! Wish I could decipher where the fuses would be.
            I am attaching to pics of the mobo hopefully someone could lead me to the fuses. Thanks
            • Reech
              • Sep 2012
              • 21
              Sorry, here's other side
              • khaahk
                • Dec 2013
                • 759
                • Estonia
                first ones to check - L12, L13
                • dj_ricoh
                  • 2073
                  that is a normal led screen.
                  the only difference in this led screen and a ccfl its the tube.
                  yours got a led stripe.
                  find a smash and test like that.
                  don`t open the mobo and start poking around
                  • MDY
                    • Jan 2014
                    • 75
                    • Spain
                    Did you check KBC? It send sime signals to LED screen...
                    • Reech
                      • Sep 2012
                      • 21
                      Thank you to all for the replies, much appreciated!
                      kkaahk, I will check L12, L13 (are they top or bottom of board?) Any directions appreciated.
                      Dj Ricoh, what do you mean find a smash and work like that?
                      MDY, are you saying KBC (key board connector?)
                      • dj_ricoh
                        • 2073
                        Test the mobo with another screen.
                        • Reech
                          • Sep 2012
                          • 21
                          I don't have another screen to test. I am also not that high a level as you all seem to be at re: testing and probing these tiny components.
                          Not sure where to test the voltages going to the screen.
                          There must be something either the led backlight or voltages to it or a fuse along the way that was shorted at some point. As I said it boots great, you just can't see anything since the backlight is not functioning.
                          If it's the mobo it's just not worth the $$$'s at this point.
                          Thanks to all for your great replies! Much appreciated!!!!
                          • Reech
                            • Sep 2012
                            • 21
                            Khaahk, I checked - L12, L13 and they check for continuity.
                            Are the L s the fuses?
                            • selldoor
                              Slow Learner
                              • 7870
                              Can you stop one of these threads running - looking through them both is very time consuming.
                              • khaahk
                                • Dec 2013
                                • 759
                                • Estonia
                                The L-s should be also working as fuses, they are ok. Power on the mainboard and do some careful voltage measurements (not to touch other pins while measuring or you might end up with dead mainboard) with the panel attached and power turned on.
                                Start counting the pins from the white triangle (right to left).
                                1-3 - should be adapter voltage
                                4-6 - should be 3.3V (which you have or else you would not see any picture on panel)
                                7 - should be also 3.3V (on stby also)
                                8 - maybe 1.5-3V (depending on screen brightness setting)
                                9 - should be above 2V
                                12 - not sure above 2V maybe digital signal, here should some info about brightness also
                                Write back the results, lets see then.
                                You also might have broken backlight on panel...
                                • MDY
                                  • Jan 2014
                                  • 75
                                  • Spain
                                  I have the same problem. Can you post that tension you have on screen conector on pin 1,2,3,,36,38,39,40?
                                  • Reech
                                    • Sep 2012
                                    • 21
                                    selldoor, I just spent `15mins searching on how to stop/delete a thread and cannot find anything. I will try again later, Thanks
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      You Cant !! What you can do is put a post on saying please put
                                      any future replies to ...... and put the link in for the other thread.
                                      If you want to make a good job of it copy and paste the questions and answers
                                      from the thread you are stopping to the thread you are keeping.
                                      • Reech
                                        • Sep 2012
                                        • 21
                                        Closing this thread, please post to:
                                        https://www.badcaps.net/forum/showthread.php?t=34610
                                        • plyanthony
                                          Razer Blade 15 no external display with attached screen disconnected from motherboard
                                          by plyanthony
                                          Computer in question : Razer Blade 15 2020 Base Model
                                          Model# RZ09-03286E22
                                          BIOS CHIP: WINBOND W25Q128BV
                                          What I'm trying to accomplish:
                                          I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
                                          What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
                                          W/Stock BIOS - 1.06:
                                          Disconnect the...
                                          02-01-2023, 09:35 PM
                                        • signal.quest
                                          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                          by signal.quest
                                          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                          03-17-2024, 10:14 AM
                                          DELL XPS 7590 Notebook 15 Specification for Upgrade or Repair
                                          This specification for the DELL XPS 7590 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7590 boardview and 7590 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 7590 Notebook...
                                          09-06-2024, 11:40 AM
